Power supply voltage range design cost
Switch mode power supplies for computers typically operate within a nominal voltage range of 100 to 240 volts, which is more cost-effective than producing separate models for different regions. Expanding the voltage range to 60 to 300 volts may involve using different components and potentially necessitating design changes, particularly if a single output voltage like 12 volts is used instead of multiple voltages. In regions with 220-240 volts, these supplies often include protection against brownouts, while those in the 100-120 volt range lack this unless configured for higher voltage. Adjustments such as larger capacitors and improved transformer insulation may incur an additional manufacturing cost of around $1, which could increase retail prices fivefold. The overall impact on sales from a wider voltage range is expected to be minimal.
Skaperen
Today's switch mode power supplies for computers mostly have a nominal voltage range of 100 to 240 volts. Whatever the added cost of making them operate over that much of a range there is must be less than the cost of having separate products for the two major narrow voltage ranges used throughout the world (separate production lines, managing inventory, etc). I'm curious what would be the cost involved in making a switch mode power supply that works over an even wider range, such as 60 volts to 300 volts. Is it a matter of just different components, or is there a point where a design change would have to be made? And would it be easier if the DC output is a single voltage (say 12 volts) as opposed to the multiple voltages a computer power supply has?
Where the mains supply is 220-240 volts, these power supplies generally have protection against extreme brownouts, and basically can still work fine at half voltage. The 100-120 volt parts of the world don't get that protection unless wired up line-to-line to get 200-240 volts.
A few of the capacitors will have to be larger value and higher voltage. Maybe better insulation on one transformer. Extra manufacturing cost probably $1 or so. Figure 5 times that when on the retail shelf in a store. Extra sales due to wider voltage range, percentage wise not discernable from zero.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
