Need to Calculate Power and Torque for a Wheelbarrow? Here's How!
  • Thread starter Thread starter RogerCh
    Calculations
To calculate the power and torque for a wheelbarrow powered by a 12v battery and motor/gearbox, consider the performance requirements based on the load and terrain. Power in watts is determined by multiplying the desired speed in meters per second by the total forces involved, including rolling resistance, inertia, grade resistance, and mechanical losses. For typical use, the total force needed is about 10% of the wheelbarrow's weight, but this can increase significantly under severe conditions. For example, a 50 lb wheelbarrow moving at 3 mph requires between 30 W and 90 W of power. Torque can be derived from power, velocity, and wheel radius, and measuring tension in a tow rope can also provide insights into power requirements.
RogerCh
How can I calculate power and torque requirements for a device resembling a wheelbarrow using 12v battery and motor/gearbox drive?
Hello Roger, :welcome:
As you can imagine, the requirements on performance come in: if your wheelbarrow has to carry a ton up a steep hill of loose sand, more is asked of it than if it only has to carry a doll on a smooth marble floor ...
Likes billy_joule
To find the power you need (in watts), you need to multiply the desired speed (in meters per second) and the summation of the forces involved (in Newtons).
The forces involved are:
There is also aerodynamic resistance, but with the low speed of a wheelbarrow, it can be ignored.
Since all of the previous are based on the weight of the wheelbarrow (##mg##), for typical use (avg acceleration of 0.15 g's, smooth & flat terrain, 15% losses) you will probably need a total force representing about 10% of the weight (##0.1mg##). But if you have severe conditions (steep grade and/or rough terrain), it can be easily 3 times as much.
So if your wheelbarrow weights 50 lb (= 222.4 N) and you want to go 3 mph (1.341 m/s), you would need between 30 W (= 0.1 * 222.4 * 1.341) and 90 W (= 0.3 * 222.4 * 1.341) of power.
If you know the power, knowing torque is irrelevant.
One option is to tow the Barrow behind a car at a constant speed. While doing that measure the tension in the tow rope. The power in watts equals tension in Newton's times the velocity in meters per second.
You can work out the torque you need from the power, velocity and wheel radius.
Use representative terrain.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
