Power Transmition System Problem
  • Thread starter Thread starter shoaibshabba
    Power System
To calculate the efficiency of the power transmission system, the power required to overcome both rolling resistance and drag must be determined. The rolling resistance at 140 mph is 200N, requiring 16.78 hp, while the drag force at that speed requires 159.57 hp. The maximum power output of the car's engine is 190 bhp at 7800 rpm. Efficiency can be estimated by comparing the total power required (rolling resistance plus drag) to the engine's maximum power output. Consideration of potential and kinetic energy changes may also be relevant for a comprehensive efficiency analysis.
shoaibshabba
Hi Guys and Girls
I have a tutorial question that requires me to calculate the efficiency of the power transmittion system in coverting engine power to vehicle motion.
I have the rolling resistance at a specific speed and the required information to calculate the power required to overcome the drag.
I thouught to calculate the power require to overcome the rolling resistance and the drag but i am not sure where to go from here!
Any help would be great!
You quite rightly state that the power required will balance the rolling resistance and the drag, at a constant speed. Power is force times velocity.
Do you know how to calculate the drag? If so where are you getting stuck?
Well the rolling resistance at 140mph is 200N and this results in an additional power required of 16.78hp.
The power required against the drag of the car at 140mph is 159.57hp.
The maximum power of the car is 190bhp at 7800rpm.
So how do i calculate the efficiency of the power transmittion system?
Either you're missing information, or you've not copied your question fully.
Does it say the maximum power of the car is 190bhp or the engine?
The exact question is -
A new sports car has the following published specifications and performance when fitted with a 1.8 litre, 16 valve, double overhead cam, turbocharged engine.
Maximum Power: 190bhp at 7800rpm
Maximum Speed: 140mph (level road,sea air)
Mass: 1200kg
Chassis Dimensions: 1.7 x 1.4 x 4.2 (widthxheightxlength)
Coefficient of drag for the vehicle is 0.34
Sea air density is 1.2 kg/m*3
If the rolling resistance of the vehicle at 140mph is 200N, estimate the efficiency of the power transmition system in converting engine power to vehicle motion.
Hi guys, i have a very similar problem to the one described here, could anyone provide insight into how to complete this?
Is there a need to take into account a gain in potential and kinetic energy of the car for efficiency?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
