Power transmitted to the second pulley
  • Thread starter Thread starter Big Jock
    Power Pulley
A pulley system is analyzed where a 150 mm diameter pulley, driven by an electric motor at 250 RPM, transmits power to a 400 mm diameter pulley against a 200 Nm load. The angle of lap for both pulleys and the angular speed have been calculated, leading to an initial power estimate of 1963 kW. Discussions focus on the impact of friction and the maximum belt tension, which is limited to half the ultimate strength of the belt at 8 kN. Participants express confusion over calculating power transmission under these constraints and seek clarification on belt tension dynamics. The conversation emphasizes understanding energy loss due to friction and the relationship between torque, angular velocity, and power in the system.
Big Jock
A pulley 150 mm diameter is driven directly by an electric motor at
250 revs min–1. A V-belt is used to transmit power from this pulley to a
second pulley 400 mm diameter against a load of 200 Nm.
The distance between the centre of the pulleys is 600 mm, the included
angle of the pulley groove = 40°, the coefficient of friction between the
belt and pulley is 0.4 and the ultimate strength of the belt is 8 kN.
Calculate the actual power transmitted to the second pulley.
So far I have
Angle of lap of small pulley= 2.722 radians
Angle of lap of the large pulley= 3.561 radians
Angular speed= 8 1/3pi
Driver speed = 250 revs min-1 = 25pi/3 rad s-1
Nice start - can you describe the operation of the setup in terms of energy?
I believe I have worked it out now and the answer should be 1963kW. Is that correct?
If that answer is correct Simon and I know the tensions is the tight and the slack side of the belt, how would I Calculate the power which can be transmitted if the maximum
tension in the belt is limited to half of the ultimate strength of the
belt? I am a bit confused with that part and can't find any relevant info or examples to compare against...
So was my answer I quoted wrong Simon?
Also still struggling with question in #4 I read the links you sent but didn't seem to help me or I have missed something along the line.
I didn't do the math - the idea was to provide you with something to compare with, so you can check for yourself.
In general, I won't do the calculation - but if you show me your reasoning I can see if what you did makes sense.
I calculated the speed of the second pulley and multiplied it against the torque to get the power, which was the answer I quoted. Now from what I I have read I believe that to be true.
If that is the case how do I set about tackling --the power which can be transmitted if the maximum
belt?
Find this very confusing but I may be staring at the correct route just need nudged in the right direction.
How did you handle the friction?
If the belt tension is not allowed to go above a certain value - what does that tell you about how to run the motor?
to get the power I used power = torque x angular velocity. I used 200Nm x the speed of the large pulley. Would that be correct or have I just calculated the power in the whole system??
Now tension in the tight side must be 8kN and using the 2.722 angle of lap I got a figure for the tension in the slackside.
Would this be correct for the original tight and slack side tensions. Think I can take it from there if it is...
Well - is the calculated belt tension too high or too low as it is?
How do I find this out?? As I am completely lost now...
Did you not just calculate belt tension above?
Are you not provided with a maximum tension figure?
Worked it all out Simon I think many thanks for you help
Great stuff :)
Likes 1 person
Hey, I'm currently working on the same paper.
If I calculate the Torque in the slack part of the belt (T2), using the angle of lap for the small pulley, would this be correct to calculate the power when using half of the ultimate strength of belt?
