Powering a small fan with solar panels
To power a duct booster fan that operates at 0.35 Amps and 110 volts AC using solar panels, a significant setup is required. Direct sunlight for about three hours daily is insufficient to run the fan continuously, especially overnight. A large solar array and an inverter would be necessary to convert the DC output from the panels to the AC required by the fan. Alternatively, connecting the fan to house power is a simpler option, but it would require professional electrical installation. This project involves complexities that go beyond basic solar panel setups.
handychick
I would like to power a duct booster fan (which I believe uses little energy) using solar panels. The store website says the fan runs at .35 Amps.
The solar panel would get direct sunlight for about 3 hours a day and indirect sunlight the rest of the day. I would like the fan to run at least all day, but overnight too would be wonderful!
What kind of solar panel/capacitor rig would I need to set up for this?
This is the fan I'd like to get.
http://www.homehardware.ca/Products/index/show/product/I5532220/name/fan_booster_duct_6
Thanks for the help!
Just to kick things off: I think the simplest possible solution would be to find out what voltage the fan requires, and then add enough solar cells in series until their open-circuit voltage adds up to about 110% of the fan voltage. Simply hooking up your fan to your series string of solar cells would clamp the panel voltage close to it's maximum power point. You'd probably need to add more than one string of cells though, to increase the current throughput to match the 0.36A of the fan. Maybe some protection diodes between each series strings and fan would be a good idea.
EDIT: Re:the panels getting clamped at the fan voltage, I'm not sure this is true. I was thinking of a battery for running the fan at night, but apparently couldn't keep the two thoughts separated. Maybe someone can correct this if it's wrong.
Looks like that fan is 110 volts AC and it does draw 0.35 amps at that voltage.
http://www.espenergy.com/6_inline_duct_fan.htm
So, it would not be a simple project to do this. You would need a large solar array and an inverter to run this fan.
You could easily run it off your house power though, provided you get an electrician to wire it up for you.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
