daniel_i_l said:
I think that this is the difference between most
evidence for evolution and evidence for physical theories. Of course it's possible to come up with ways that evolution
could have been falsified [the famous rabbit in the Cambrian for example], but that isn't as powerful as an experiment designed such that one of two possible outcomes is incongruous with evolutionary theory. Has such an experiment ever been done?
Sure you can design experiments to test individual parts of evolutionary theory (remember evolutionary theory is a big unifying theory, as such it incorporates many parts).
Suppose we wanted to test speciation, using evolutionary theory we predict that for a population, in which subsets become divide off each individual subset will continue to undergo selective pressures exerted by the environment until such a time that the populations no longer interbreed even if brought back together eventually.
Just such a famous experiment was carried out by
http://evolution.berkeley.edu/evolibrary/article/_0_0/evo_45". What she found was that when a population is isolated to two different environments, even after they're brought back together, reproductive isolation starts.Another good example would be if we wanted to test the idea of selection itself. We could predict with evolutionary theory that allele frequencies in a population may not change randomly, but rather as a result of selection. How could we test this?
Suppose we wanted to look at how predation affected allele frequencies, after all evolution says that population under selective pressure should show adaptive changes due to the differential survival and reproduction of those changes. We could for instance, take a population of animals in the lab, let them live without selective pressure from predation for a time. Then introduce to the population, a predator which would provide a selective pressure. If evolutionary theory is right, we should see a change in allele frequencies over time (generations). We could even test this in the wild by introducing a new predator to a population which had not seen said predator before. That is to say, we have experimental (both dependent and independent) variables we can go in and manipulate.
Again, such a thing has happened in both the lab and in a "natural lab".http://evolution.berkeley.edu/evosite/evo101/IVB1bInthelab.shtml" Suppose we wanted to test the foundation of evolutionary theory; descent with modification. Evolutionary theory says that some clades of organisms should share common features because of shared ancestry and this should be to the exclusion to other clades. Here we can even get maths involved!
We could then use homology (evolutionary derived shared features) as a null hypothesis; "Such and such structure is not homologous in these two organisms".
We could then go out into the world and gather data, say the gene sequence (molecular genetics), the embryonic development (Evodevo) of said feature, the protein structure (proteomoics) etc.
We could then array these features in a matrix (lots of them!) and apply statistical tests to our observations and based on those tests accept or reject the null hypothesis.
If we were unable to reject the null hypothesis ever (that structures aren't homologous), you would certainly falsify evolutionary theory. There
must be homologies shared between clades if evolution were true. Low and behold we do find homologies throughout clades of varying sizes (the continuity of the mammalian arm, the development of the notochord in vertebrates, etc).
We can then use everything we know about evolutionary theory to predict or make models of lineages and of course, some of those models are falsified from time to time. Say for example the common derived characteristic of the mammalian and mollusk eye, which was falsified on the basis of homology. There are literally thousands of examples of these different tests of evolutionary. So many, that I'm not even sure you could find a collective source for them all. I'd suggest, barring taking a upper level evolutionary biology course, you start with authors like Sean B. Carrol, Jerry Coyne, Steven Pinker, Richard Dawkins (at least his stuff involving evolution, not religion), Stephen Gould, Matt Riddley, etc
Honestly, I can't think of (with the exception of quantum physics) a scientific theory that has been more tested and scrutinized than evolutionary theory (And we don't even understand quantum physics in the way we understand evolutionary theory!)
