Pressure and Forces within Fluids
The discussion centers on the pressure and forces exerted by water in three differently shaped tanks filled to the same depth. Tank C, having the largest surface area, exerts an upward force on its sides, while the pressure at the bottom of Tank C is greater than that of Tanks A and B due to its larger area. The force on the bottom of Tank C is equal to the weight of the water in the tank, and the force exerted by the water on the bottom of Tank C is greater than that on Tank A. The pressure at the bottom of Tank B is equal to that at the bottom of Tank C. Understanding that pressure is determined by the formula Pressure = Force/Area is crucial for solving these comparisons.
daisy497
Tank A
|..h2o...|
|..h2o...|
|_h2o__|
Tank B
.\..h2o../
..\.h2o./
...\h2o/
Tank C
../.h2o.\
./..h2o..\
/__h2o__\
The three tanks shown above are filled with water to an equal depth. All the tanks have an equal height. Tank A has the middle surface area at the bottom, tank B the least and tank C the greatest.
(Select T-True, F-False, G-Greater than, L-Less than, E-Equal to. If the first is F the second L and the rest G, enter
FLGGGG).
A) The water in tank C exerts an upward force on the sides of the tank.
B) The pressure exerted on the bottom of tank C is greater than for the other tanks.
C) The force due to the water on the bottom of tank C is ... the weight of the water in the tank.
D) The force exerted by the water on the bottom of tank C is ... the force exerted by the water on the bottom of tank A
E) The pressure at the bottom of tank B is ... the pressure at the bottom of tank C
I can't seem to figure this one out. I've made several attempts and they are all wrong.
Welcome to PF.
What determines pressure?
