Pressure and temperature -- the effects of one upon the other
Increased temperature generally leads to increased pressure, particularly in ideal gases, but the relationship is not strictly causal. Pressure can influence temperature, depending on the material's equation of state, meaning that changes in one do not necessarily cause changes in the other. For example, pressing down on an object may not significantly raise its temperature, and the Earth's core temperature is influenced by the pressure from the crust and mantle. Understanding these relationships requires examining the specific equations of state for different materials. The correlation between pressure and temperature is important for calculations in thermodynamics and geology.
cGibson
Greetings,
I get that increased temperature increases pressure. But does increased pressure increase temperature. For example: 1) If I press down on a table with a heavy object, does it increase its temperature. 2) Or does the pressure of the crust and the mantle of the Earth, contribute to the increase of the temperature of the core?
Thanks!
Science news on Phys.org
You should probably discard the idea of cause and effect here. It is not necessary and is a hindrance to understanding.
All other things being equal, there is a correlation between pressure and temperature in an ideal gas. If temperature is higher, pressure must be higher. If pressure is higher, temperature must be higher. It is not required that the increase in temperature caused the increase in pressure. It is not required that the increase in pressure caused the increase in temperature. It is enough that when given an increase in one you can calculate the increase in the other.
It is the same way with force and acceleration and f=ma. It does not matter whether the force of your hand on a ball causes an acceleration or whether the acceleration of a car causes a force of the seat on your posterior. It is enough that you can calculate either one when given the other.
First, it is not necessarily true that increased temperature means an increase in pressure. It depends on the equation of state for the material. For example, if we use the ideal gas law as our EoS then we know that
## pV = mRT ##
And so we see that if the temperature of a fixed mass of gas goes up the product of the pressure and volume must go up. It could be that the volume goes up and the pressure is fixed, or the other way around.
You can find EoSs for solids if you look within the fields of geology and mineralogy. Once you examine these, you should be able to predict how increasing temperature impacts pressure and vice versa.
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
