Pressure exerted by an ideal gas
80 replies · 14K views
Lord Jestocost said:
The point is (simplified): due to the huge number of collisions all molecules acquire finally the same average velocity.
To say it exactly: due to the huge number of collisions the time averages of the velocities of all individual molecules are finally the same when equilibrium is reached. Equilibrium in the sense that the state of the gas will be statistically stationary, i.e., the particles in the gas will settle into some velocity distribution independent of time, position or initial conditions.
sophiecentaur said:
In an ideal gas, the only collisions are with the wall so the same distribution of velocities will exist...
No idea how elastic collisions with "rigid" walls will result in a velocity distribution when one looks at individual gas molecules in course of time.
No idea how two molecules with different speeds would, as the result of a collision, end up with their speeds 'more nearly equal'. The distribution of speeds would not change, would it?
To progress to the gas laws, the temperature of the walls ('vibrations') would imply a range of momentum values transferred from and to the molecules so that the gas molecules would end up with a speed distribution corresponding to the temperature of the container.
To understand how particle collisions take place and what the kinetic theory of ideal gases is about, I recommend to read the textbook "PHYSICS" by David Halliday and Robert Resnick. There is a chapter about collisions between particles in two or three dimensions and there is a chapter about the kinetic theory of gases and the microscopic definition of an ideal gas.
PainterGuy said:
Thank you, everyone.
@Lord Jestocost, your analogy of springs really helped me get a conceptual understanding of bulk modulus and how it affects speed of sound.
If we have a cylinder with a moveable piston at the top. The cylinder is sitting on a weighing balance. As the piston is pushed downward, I believe that the balance would read more. The movement of piston gives gas molecules a total downward momentum. The temperature is kept constant. After a short time, the balance would go back to its original reading before the piston was moved downward and the cylinder would experience the same pressure at every point. It means that after a short time all the momentum transferred thru piston in one direction gets distributed in all directions equally. Do I have it right? Thank you.
Imagine that you push the piston by suddenly placing a certain mass on it. What will the weighing balance show after everything has come to rest?
I don't have that book but I do have several A Level Physics textbooks and I have a Degree Level Thermodynamics book (Zemanski) somewhere in a cupboard. Collision between two spheres was something we did when I was at School and I would be surprised if you could find anywhere where it says that the final speeds become nearer equal than the initial speeds. Can you photograph a page where that is written?
The derivation of the simple gas laws is not hard and it does not result in all molecules acquiring the same speed - which is what I challenged you one initially. (Perhaps you didn't mean what you wrote in that sentence). The distribution of mean square velocities will remain appropriate for the temperature of the gas and container.
sophiecentaur said:
...which is what I challenged you one initially. (Perhaps you didn't mean what you wrote in that sentence)...
See my comment#31
See my comment#31
Jeez, I had to read that several times but, I can go along with it in a practical case. The problem with the ideal gas case is that there can be no collisions between molecules because, by definition, they have zero volume so they will not collide - the walls are the only thing that they collide with so they will each remain with the same kinetic energy.
From https://en.wikipedia.org/wiki/Ideal_gas
The ideal gas model depends on the following assumptions:
  • The molecules of the gas are indistinguishable, small, hard spheres
  • All collisions are elastic and all motion is frictionless (no energy loss in motion or collision)
  • Newton's laws apply
  • The average distance between molecules is much larger than the size of the molecules
  • The molecules are constantly moving in random directions with a distribution of speeds
  • There are no attractive or repulsive forces between the molecules apart from those that determine their point-like collisions
  • The only forces between the gas molecules and the surroundings are those that determine the point-like collisions of the molecules with the walls
  • In the simplest case, there are no long-range forces between the molecules of the gas and the surroundings
From [PDF]Here - University of Southampton
Think about a single molecule inside a gas which is in thermal equilibrium. Our chosen molecule continually suffers collisions; sometimes it gains energy from a collision and rebounds at high speed; sometimes it is briefly brought almost to a standstill. Our molecule (the system) is continually exchanging energy with the gas (the reservoir) - we say that its microstate is changing, even though in the macroscopic world all the measurable physical properties of the gas as a whole stay the same in time. Although we cannot predict the velocity of our molecule at any moment, we can say precisely that the relative probability of a state of velocity v is given by the Boltzmann distribution...
Thank you.
As I learn more I believe that my ability at using algebra and abstraction would improve. I understand your point but I didn't even attempt to use any numbers or symbols because I didn't think there was any need for it. My question was general, and at the same time some other members were already able to help me in previous posts. Nonetheless, your point is well taken and I agree that it does help to formulate and track the information if proper symbols and numbers are used.
@Lord Jestocost: The balance would measure the weight of gas plus the mass atop the piston. The piston imparts the velocity along a single axis but with time all this 'additional' velocity gets distributed along all the axes assuming the piston is thermally insulated. Do I make any sense? Thank you.
Momentum is strictly conserved in every direction independently. It does not redistribute in any other direction. The piston imparts momentum into the system. If there is no countering force, the system gains momentum which cannot be lost in any other direction.
Thank you.
I do understand that the momentum should be conserved in every direction. Doesn't the piston impart velocity to the molecules along a single axis?
Could you please elaborate on it a little? Thank you.
Let us consider a box-shaped tank containing gas. And momentum.
So, every wall is absorbing momentum from the gas, an alternative way to say that is that every wall is giving momentum to the gas. Yet another way to say that is to say that the gas pushes the wall, or the wall pushes the gas.
Each wall can push the gas only in one direction, because there is no friction between the wall and the gas.
So, if the 'ceiling' wall gives the gas some momentum, that momentum can be absorbed by the 'floor' wall, but not the side walls.
Thank you.
So, doesn't this imply that the molecules will have greater velocity in that particular direction? Greater velocity along a certain direction also implies a larger pressure along that direction. Thank you for your help.
Let's consider gas molecules that don't collide with each other, in a box-shaped container that has perfectly smooth walls. In this special case it is true that extra vertical pressure stays extra vertical pressure forever. Are we interested about this case?
The above situation is very abnormal. Normally pressure becomes isotropic very quickly. Like when walls are not smooth. A rough side wall exerts vertical forces on gas molecules, not on gas, but on individual gas molecules.
PainterGuy said:
Thank you.
I do understand that the momentum should be conserved in every direction. Doesn't the piston impart velocity to the molecules along a single axis?.
Yes it does. The molecules bounce off of the advancing piston with increased velocity and as a result the temperature of the gas increases. The amount of change depends on how the compression is carried out, for example the quicker the compression the greater the velocity change.
Thank you.
You have rightly understood my question. The first case with ideally smooth walls is not practical because as you say that extra pressure would stay like that so I'm interested in the second case.
Now I could rephrase my original question like this that what's the reason that pressure would become isotropic? I understand that the even the majority of molecules which run into the moving piston at 90° won't reflect back at 90° due to the bumpiness of piston surface. For example, if you throw a ball at 90° toward a smooth wall, it would reflect back along the incident path at 90°. But if the wall has a slope as shown in the attachment, the ball won't bounce back along the incident path. Would you like to elaborate on it a little more like why pressure becomes isotropic? Thank you.
Well I don't know, but let's consider a piston and a cylinder that look like this as seen from the side: |V|
And then let's ask some questions:
1: what kind of momentum are we giving to the gas when we push the piston down?
2: what kind of speed are we giving to the molecules when we push the piston down?
3: Some question about pressure when we push the piston down
1: Downwards momentum. Sideways momentums cancel out each other.
2: Molecules get extra speed into the direction of the normal of the surface, if the surface is perfectly smooth, if rough then all directions.
3: Molecules get more speed so pressure increases. And volume decreases so pressure increases for that reason too. Now I should say something about why pressure increases in all directions ... well if the molecules don't collide with each other then the molecules are like light. So if we shine a light beam into container with perfectly smooth walls and this shape: |V| what happens? ... Well the beam can't be perfectly collimated, so the initial randomness is amplified as the beam bounces around, and the light becomes diffuse very quickly.
Thank you. I was trying to understand Bernoulli's equation from conceptual point of view and was stuck at that point where I couldn't understand how pressure became isotropic. Thanks for helping to come over that obstacle.
Hi
The equation PV=nRT for ideal gases is also applicable in an atmosphere free from gravity. How do we find the pressure exerted by a liquid in an atmosphere free from gravity? The formula ρgh cannot be used because it uses gravitational constant. Thank you.
This liquid is just sitting there, stationary?
How much pressure are you exerting on it? That's how much pressure it is exerting on you.
Thank you.
Yes, the liquid is just sitting there stationary.
Let's start like this. There is a 1-liter container. The container is filled up with water to the maximum. The water molecules are hitting the faces of container just like gas molecules and this motion of the molecules is not dependent on the gravity. When this container is put in an environment free from gravity, what pressure will the water molecules exert on the container faces? I'm mentally visualizing water molecules moving around like gas molecules except that the water molecules need to stick together into a single lump. For example, mean free path for water molecules is 0.2 nm while for the air molecules at 25 C and 760 mm Hg pressure is almost 70 nm. Where am I going wrong? Thanks.
That idea is totally correct for a gas not under gravity; in a container in deep space.
It only works for 'small volumes' of a gas under gravity. Imagine a 1m3 cube at sea level. Let it be in a cuboidal bubble of massless material, to make it easier. That cube of air will have a mass of about 1.2kg (weight of 12N) and the weight will be acting downwards, spread over the 1m2. So the pressure on the lower face will be 12Pa greater than the pressure acting on the upper face. The pressure inside the cube will vary by 12Pa! so it's not actually isotropic but what is the fractional difference if the overall pressure is 100kPa?? (=12/105! Could you easily measure that (the answer is 'only just')? Now consider a 1l cube; the pressure difference would be 1.2Pa. The limit, as the cube gets smaller and smaller is Zero so, at a given point, the pressure can be said to be the same in all directions (isotropic) because the 'bubble' has no volume..
PainterGuy said:
Hi
Liquids are the hardest to consider; the pressure exerted by an ideal solid, floating in weightless conditions, is Zero because the forces of repulsion and attraction are in equilibrium (if it is at constant temperature). I think the best description of the 'pressure' at the surface of a liquid a liquid would be the Vapour Pressure; the surface molecules are constantly leaving due to their kinetic energy so, if you contain it in a bubble, the bubble will continue to expand and lose energy (lowering its temperature) so it wouldn't be an equilibrium situation. With a warm liquid bubble in an atmosphere, the pressure will exceed the atmospheric pressure by its vapour pressure until it has reached equilibrium through loss of its internal energy.
I think this is a topic that requires one to think around all the possible situations oneself and to identify the details of the substance and its environment. A sort of Private, Internal PF Thread. The answers to many of those 'what if' questions can best be found within your own mind. It can make the brain ache, of course.
I think in the absence of gravity and other external forces the forces between the molecules themselves will be dominant and the water will tend to take a spherical shape. Surface tension theory can be used to calculate the pressure difference across the water surface.
Look up the videos showing water drops on ISS .
Statically indeterminate.
If an ideal rigid container is filled completely with an ideal incompressible liquid, the pressure on the container walls is not determined.
Edit: If the container were to shrink by any finite amount, the pressure would become infinite. If the liquid were to expand by any finite amount, the pressure would become infinite. If the container were to grow by any finite amount, a void would be created. If the liquid were to shrink by any finite amount, a void would be created.
Evaporation will occur for as long as the vapour pressure in the surrounding region of air is lower than the vapour pressure of the droplet.
Like I said, liquid is a difficult state to understand. I guess that the vapour pressure of some solids would need to be considered under some conditions.
Now I can imagine that why it's difficult to determine the pressure exerted by a liquid on the walls of a container in an environment free from gravity assuming that the liquid 'just' touches the walls. I wouldn't say that no pressure would be exerted by the liquid when it's 'barely' touching the walls of container, it's just that the pressure is indeterminate.
I really appreciate your help.
