Pressure~Gas Law Homework - Find Avg Pressure
  • Thread starter Thread starter clovergogo
    Law
To find the average pressure exerted on a circular region by falling rain, the momentum change of each raindrop must be calculated, considering the mass and velocity before impact. Given that rain falls at a rate of 1.2 g/s and each drop has a velocity of 10 cm/s, the total change in momentum per second can be derived. The pressure can then be calculated using the formula P = F/A, where F is the total force from the raindrops and A is the area of the circular region. Proper unit conversion and application of the elastic collision principle are essential for accurate results. The discussion emphasizes the importance of correctly applying physics equations to solve for pressure.
clovergogo
rain is falling normally on a circular region of radius 25cm at a rate of 1.2gs-1
suppose the velocity of each raindrop just before it reaches the region is 10cms-1
and the collision between each raindrop and the region is perfectly elastic
find the avg pressure exerted on the region
take g=9.8ms-1
P= F/A
momentum, then the Pressure
is it ...P = (0.0012X10+0.0012X9.8) / 0.25^2 pi??
take g=9.8ms-1
P= F/A
If the collisions are perfectly elastic, what is the change in momentum of a raindrop of mass m striking this area?
Now take N such raindrops every second such that Nm = 1.2 g. What is the total change in momentum of the raindrops every second? How is that change in momentum every second related to the force imparted to the circular area? What is that force/unit area?
AM
can i take t=1
then mv-mu/t = F can be count
then mass = 1.2 X 1
then Pressure (P) can be count
clovergogo said:
can i take t=1
then mass = 1.2 X 1
If you use the units and parentheses properly, the method will work. What is u if the collision is perfectly elastic?
ehild
