Calculating Hydraulic Pressure in a Neutron Star
In summary, the gravitational field inside a neutron star is proportional to the mass inside the star, and is 3.14x10^{31} Pa.
j-e_c
Assuming a neutron star is made from an incompressible material, what is the hydraulic pressure 50m below the surface?
Mass = 1.98x10^30kg
Radius = 10km
2. The attempt at a solution
g=GM/r^2 = (6.67x10^-11 x 1.98x10^30)/ 10000^2 = 1.32x10^12 m/s^2
P=P[tex]_{0}[/tex] + [tex]\rho[/tex]gh Pa
[tex]\rho[/tex] = m/v = 1.98x10^30 / (4/3 x pi x 10000^3) = 4.73x10^17 kg/m^3
If pressure in space is 0 Pa, then P = 0 + 4.73x10^17 x 1.32x10^12 x 50
= 3.12x10^31 Pa
Is this correct? Thank for your time!
Edit: I think it might be wrong because my equation assumes that space (as a vacuum) and the star are one material (?) :s.
Use the differential equation of hydrostatic equilibrium:
[tex]\frac{dP}{dh} = -\rho g[/tex]
Remember that the gravitational acceleration [tex]g[/tex] changes with [tex]h[/tex]
In your calculation, you assumed that it was constant and equal to the surface gravitation. That is incorrect.
[tex]\rho[/tex], on the other hand, is constant as the star is incompressible.
Thanks, for your reply. Here is my second attempt:
dP = - [tex]\rho[/tex]gdh
[tex]\frac{dP}{dh}[/tex] = -[tex]\rho[/tex]g
[tex]\int[/tex][tex]\frac{dP}{dh}[/tex]dh = [tex]\int[/tex]-[tex]\rho[/tex]gdh
P = -[tex]\rho[/tex]GM[tex]\int[/tex][tex]\frac{1}{r^{2}}[/tex]dh between 10000 and 9950
P = -[tex]\rho[/tex]GM [[tex]\frac{1}{r}[/tex]] 10000...9950
= -[tex]\rho[/tex]GM [[tex]\frac{1}{10000}[/tex]-[tex]\frac{1}{9950}[/tex]]
=3.14x10[tex]^{31}[/tex] Pa
I apologize for integrating r with respect to h, if that was confusing.
That too is incorrect. ;) Though you're on the right track!
Remember that a spherical shell contributes no [tex]\frac{1}{r^2}[/tex] field inwards. That is to say, when calculating the gravitational field inside the star at a radius [tex]r_0<R[/tex], you must only regard the contribution of the mass inside, at radii [tex]0<r<r_0[/tex], as all the mass on the outside contributes nothing to the gravitational field!
OK, I've got it, thanks RoyalCat!
You're welcome!
As a hint, the gravitational field rises linearly with the radius inside the star, in case you happen to get anything different.
What is pressure in a neutron star?
Pressure in a neutron star refers to the force exerted by the particles, such as neutrons and protons, that make up the star. This pressure is a result of the extreme density of particles within the star.
How is pressure created in a neutron star?
Pressure in a neutron star is created by the immense gravitational force that compresses the particles together. As the star's mass increases, so does the pressure, until it reaches a point where it can no longer support itself and collapses.
What is the importance of pressure in a neutron star?
Pressure is crucial in balancing the gravitational force in a neutron star. Without enough pressure, the star would collapse under its own weight. Pressure also determines the stability and lifespan of a neutron star.
How does pressure affect the behavior of matter in a neutron star?
Pressure plays a significant role in determining the properties of matter in a neutron star. It can affect the temperature, density, and composition of the particles, ultimately influencing the overall behavior and evolution of the star.
Can pressure in a neutron star be measured?
Yes, pressure in a neutron star can be estimated using various theoretical models and observations. However, due to the extreme conditions in a neutron star, it is challenging to directly measure its pressure using traditional methods used in laboratory settings.
19K
9K
  • Astronomy and Astrophysics
