Pressure/temperature question about HVAC
  • Thread starter Thread starter stryped
    Hvac
Understanding the impact of evaporator size on superheat in HVAC systems involves analyzing the refrigerant cycle. Utilizing a thermodynamic model or specialized HVAC software can help determine how changes in evaporator size affect superheat compared to baseline measurements. The relationship between evaporator size and superheat is crucial for optimizing system performance. Accurate calculations can lead to better efficiency and reliability in HVAC operations. Exploring these tools can enhance understanding and application in real-world scenarios.
stryped
I have been reading about hvac and have a question. I downloaded a neat app where you can input the refrigerant type, (say r22) and the low side pressure as well as the suction line temp, and it will give you the superheat of the refrigerant. Is there a way to figure out if a person installed a larger or smaller evaporator, how that would effect the superheat compared to the baseline?
The best way to figure this out is to either set up a thermodynamic model of the refrigerant cycle and take a look at the effect, or potentially utilize software which automates this analysis in an HVAC context.
See here: https://en.wikipedia.org/wiki/Heat_pump_and_refrigeration_cycle
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
