How Is PT Related to PA, PB, and PC in a Rigid Gas Mixture?
  • Thread starter Thread starter ksle82
    Volume
In a rigid container with a mixture of gases A, B, and C, the total pressure PT is related to the individual pressures PA, PB, and PC by the equation PT = PA + PB + PC, assuming ideal gas behavior. Key assumptions include constant volume, the gases being ideal, and that the individual gases are at the same temperature as the original mixture when measured. The discussion highlights that the assumption of "no heat loss" should be refined to "constant temperature" for clarity. It is also noted that Dalton's law of partial pressures applies only to ideal gases, which is crucial for accurate pressure calculations. Understanding these relationships is essential for analyzing gas behaviors in rigid containers.
ksle82
A rigid container is filled with a mixture of three gases: A, B and C. The pressure gage reads PT. The container is evacuated and filled with an amount of gas A equal to that in the original mixture. The gage now reads PA. This process is repeated for gases B and C with the pressure gage reading PB and PC respectively. How is PT related to PA, PB, and PC? What assumptions are made?
Assumptions: 1) constant volume, 2) no heat loss, 3)PT>TA,TB,TC
-these are the assumptions i can think of as of right now. are there any other relevant ones?
As for the question How is PT related to PA, PB, and PC?
Answer: PT = PA + PB + PC
- is this the right aswer or it's more complicated than that?
You're final answer would be right with one more assumption: what kind of gas does it need to be?
Also, I think assumption #2 is worded a little wierd. Since the mixed gas is removed and a new source of gas is used to fill the container with A, I don't think it makes sense to say "no heat loss". I think a better way to phrase it would be "constant temperature".
You're right. The "no heat loss" assumption was kind of vague. I should have said that the container is fully insulated so no heat can escape once the it is fully closed.
I don't think i can asume constant temperature since no info in the question giving hint that i can make that assumption.
I think u know that this depends on gases,
if it's the case of perfect gases, just use PV=nRT
so cos it's a constant volume & temperature, u'll get:
V/(RT)=nA/PA=nB/PB=nC/PC=(nA+nB+nC)/PT
I wish I was helpful,
I would say that PT=PA+PB+PC but it assumes the individual gases in the container are kept at the same temperature as the original mixture.
In the mixture, A occupied only a portion of the volume, as did B and C. So when it is all by itself, A must occupy a larger volume. If A is injected at the same temperature as the original mixture, it will cool as it expands to the larger volume. I am assuming it is warmed to the original temperature of the mixture before PA is read. Ditto for the other gases.
AM
Don't forget that Dalton's law of partial pressures does not apply to all gases. It applies to ideal gases. In the case of a non-ideal gas the partial pressure does not have the interpretation that it is the pressure that the gas would exert if it alone occupied the entire volume of the container.
