Primes, pigeon holes, modular arithmetic
HmBe
Don't have a clue how to even start this one, sorry.
I don't have much time to help with this one. Do you recall what the pigeonhole principle states?
The n elements of a set get mapped to n-1 elements of another set, so no matter what, there are elements ai and aj which get mapped to the same element or the same 'hole'.
Yeah I'm happy with the pigeon hole principle, although I can't quite see how it applies as a can be any natural number or 0, so surely the size of set A is infinite?
That can't be meant, because the pigeonhole principle can only be used if ##\mathcal A## is finite. So ##0\leq a,b<\sqrt p## probable means ##(0\leq a<\sqrt p)## and ##(0\leq b<\sqrt p)##. This would give you ##|\mathcal A| < (\sqrt p+1)^2 = p+2\sqrt p+1##.
Now I'd look at the function ##f(x,y)=x^2+2y^2## for all pairs ##(x,y)\in\mathcal A##.
Ah right yeah I thought they were too separate inequalities which really messed me up. Quite simple now.
Got down to this..
(b-b')^2 + 2(a-a')^2 = pk
for some integer k.
I'm having a little struggle getting rid of the k (so to speak).
a, b, a', b' are all < sqrt(p)
so
(b-b')^2 + 2(a-a')^2 < 3p
so k < 3
if k = 1 we're fine, no worries.
but what about the k = 2 case? I feel like I should return to the x^2 = -2 (mod p) to get some fact about p I could use...?
Thanks for the help.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
