Why does negative charge reduce the potential of a metal plate in a capacitor?
When a positive charge is applied to metal plate A, it induces a negative charge on the nearby plate B through electrostatic induction. This negative charge on plate B effectively reduces the potential of plate A, which in turn increases its capacitance as described by the formula C = Q/V. The presence of the negative charge creates a scenario where the entire system behaves like a neutral object, balancing the charges. The potential difference between plates A and B is influenced by the movement of electrons, which are attracted to the positive charge and thus reduce the potential available for discharge. Understanding this interaction clarifies why negative charge decreases the potential of plate A in a capacitor system.
logearav
dear members,
when a positive charge is given to a metal plate say A, negative charge is induced on the nearby plate B(say) due to electrostatic induction. the presence of negative charge reduces the potential of the plate which increases the capacitance of A by the relation c=q/v. my question is why negative charge reduces the potential of A.
thanks in advance
logearav said:
dear members,
thanks in advance
According to me, with the B plate negatively charged, the whole system (A & B) is something like a neutral object. Look, a neutral atom consists of protons (in the nucleus) and electrons.
In fact the potential between A and B is increased.
Potential is simply "electron pressure". If you squeeze some electrons into a piece of metal, that repulsion is the pressure (potential) they are under. However, if you bring a positive charge near that piece of metal, that positive charge pulls the electrons toward some point on the object away from the lead wire attached to that object, reducing the force that would otherwise cause them to leave that object through the wire on the opposite side of the object.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
