Can a Probability Distribution Function Be Flat?
A probability distribution function (PDF) can be flat, representing a uniform distribution, but it must always be non-negative. The confusion arises when differentiating the PDF, as this derivative can have positive and negative values, but it does not represent a probability. A proper distribution function must be increasing to ensure its derivative, the probability density function, remains non-negative. The original statement incorrectly suggests that a flat PDF can have both positive and negative impulses, which is not possible. Understanding the distinction between the PDF and its derivative is crucial for clarity in probability discussions.
reddvoid
If probability distribution function is flat like a rectangular signal then probability density function which is differentiation of probability distribution function will have positive and negative impulses, but probability density function cannot be negative. . what's wrong in this . . . Can't probability distribution functio be flat ?
Sometimes, "probability distribution function" is used as "probability density function".
The differentiated function is not a probability.
neither is the rectangular function a distribution function. a distribution function must be an increasing function (so that the derivative, which is the p.d.f., is always non-negative).
There is nothing inherently wrong with a probability distribution function being flat. In fact, a flat PDF is often used to represent a uniform distribution. However, the issue with the statement is that the PDF cannot have positive and negative impulses. The PDF represents the likelihood of a random variable taking on a specific value, and it cannot have negative values. The statement may be confusing the PDF with the derivative of the PDF, which can have positive and negative values. However, the derivative is not the same as the PDF itself.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
