Probability of finding a particle in a 1D Box
The discussion focuses on calculating the probability of finding a particle in a 1D box of size L within specific regions of size 0.01L at designated points. The correct approach involves integrating the probability density function, given by P=|\Psi(x,t)^2|, over the specified intervals. Participants emphasize the importance of substituting the wave function \Psi(x) into the integral before performing the calculations. The expected probabilities at the specified locations are 0%, 1%, 2%, 1%, and 0%. The conversation concludes with a participant expressing gratitude for the assistance received, indicating a clearer understanding of the problem.
scottnoplot
Determine the probability of finding a particle in a 1-D box of size L in a region of size 0.01L at the locations x = 0, 0.25L, 0.5L, 0.75L and L when it is in its ground state. As percentages
\Psi(x)=\sqrt{\frac{2}{L}}sin(\frac{nxPI}{L})
P=\Psi(x,t)^2
I'm not even sure if I've got the right equations there, I've tried loads of different ways of doing this and cannot get the right answers, which are 0%,1%,2%,1%,0%
Cheers
ok, finding probabilities means integrating the probability density - P=|\Psi(x,t)^2| - over parts of the box
try integrating over the whole box first, what does this give you?...
\int|\Psi(x,t)^2| = |\Psi(x,t)^3| /3
I think that's right.
Your answer cannot be a function of x, since you are integrating over x. Try substituting your expression for \Psi(x) from your first post before you integrate.
You need to integrate |psi^2| from x=0 to x=0.01L , from x=0.245L to 0.255L, etc
Try to plot psi, |psi^2| and the integral of |psi^2| from 0 to x (remember that the integral is the probabilty of finding the particle in the limits of integration...)
Thanks guys, got a bit of extra help and the penny has dropped now. cheers
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
