Probability, There are 20 laborers to four different construction jobs
Kinetica
Please help me in my attempt:
There are 20 laborers to four different construction jobs including 4 workers of ethnic minority. The first job required 6 laborers;
the second, third, and fourth utilized 4, 5, and 5 laborers, respectively. What is the probability that:
a) an ethnic group member is assigned to each type of job?
b) no ethnic group member is assigned to a type 4 job?
a) [16!/(5!3!4!4!)]/[20!/(6!4!5!5!)]
equals to 0.0051. Thus, there is 0.5% chance that each minority would be assigned to each job
b) I offer one way:
1- [16!/(6!4!5!1!)] / [20!/(6!4!5!5!)]
Please offer another way.
Can you explain your logic behind your answer to part (a)? It may be obvious to you since you're in the class, but I don't see where your expression came from off the top of my head.
OK - Now I am correcting myself a bit. The logic behind part a answer:
The total number of all the possible options is [20!/(6!4!5!5!)].
Now I know that I have to put 4 minority workers into each job. So I have 4! options of distribution of those minorities. I also have 16! workers that are left to work with the rest of the jobs. So it goes:
(4!16!)/(5!3!4!4!)
That comes out to be greater than 1.
Then, the final answer for part a is:
(4!16!)/(5!3!4!4!) divided by [20!/(6!4!5!5!)]
Oh, OK. That looks right to me.
For part (b), what do you mean when you say a type 4 job?
It means the very last job, the fourth one.
So (b) isn't a complementary event to that of (a), so the method you tried isn't correct.
b) I offer one way:
I get a totally different answer for (a). We can (randomly) assign workers to jobs sequentially; that is, first assign job 1, then job 2, etc. For job 1 there are N1 = 4 minority people and N2 = 20-4 = 16 non-minorities. The probability of assigning k1 minorities to job 1 is the hypergeometric distribution with parameters (N1,N2,n) = (4,16,6):
p_1(k_1) = \frac{ {N_1 \choose k_1} {N_2 \choose n-k_1}}{{N_1 + N_2 \choose n}}, where we use N_1 = 4,\; N_2 = 16,\; n = 6, \; k_1 = 1. Now, given that job 1 has one minority member, we job 2 sees the situation with N_1 = 3, N_2 = 11, n = 4, so p_2(k_2) \equiv P\{ k_2 | k_1 \} is given by the hypergeometric distribution with the new parameters. Update again to get the probability that job 3 gets one minority, given that jobs 1 and 2 each have one, etc. Now, of course, the overall probability is the product of the individual probabilities, since P\{ k_1=1, k_2=1, k_3=1, k_4=1 \} = P\{k_1=1\} \cdot P\{ k_2=1 | k_1 = 1 \} \cdot P\{k_3 = 1 | k_1=1, k_2=1 \} <br /> \cdot P\{ k_4 = 1 | k_1=1, k_2=1, k_3=1\}.
RGV
[QUOTE=Ray Vickson}
I later corrected myself. Please see if my solution that follows the original posting is correct?
Thank you!
Kinetica said:
Ray Vickson} I later corrected myself. Please see if my solution that follows the original posting is correct? Thank you![/QUOTE said:
For part (a) I get answer = 40/323 \doteq 0.123839.
What do you get for part (b)? I know you wrote something before, but are you sure that was the correct answer? Give reasons, don't just write things down.
RGV
Thanks, this is correct!
So (he repeats): what did you get for part (b)?
RGV
