Problem from AP French Special Relativity
The discussion revolves around a physics problem involving two masses connected by a spring, where a burst of radiation alters their masses. Participants emphasize the need for energy and momentum conservation to solve the problem, particularly noting that the relative velocity of the masses is zero at maximum spring extension. One user expresses difficulty in applying the conservation equations correctly and seeks assistance. After multiple attempts and discussions, the user ultimately resolves the problem independently. The conversation highlights the importance of understanding the timing of radiation absorption in relation to the system's oscillation.
george2
1.Hi!I need some help with the following problem:
A body of mass m1+dm is connected to a body of mass m2-dm by a spring of constant k and negligible mass.The system is at rest on a frictionless table.A burst of radiation is emitted by the first body and absorbed by the second changing the masses to m1 and m2.If the time of transit of the radiation is negligibly small compared to the period of oscillation show that the maximum extension of the spring is given by:x=cdm\sqrt{\frac{m_{1}+m_{2}}{km_{1}m_{2}}}
2. E=dmc^{2}, E=cp for the photon
3. I think that energy and momentum conservation are needed.However i don't know which are the initial and final moments for which i should apply energy and momentum conservation. This is not exactly a homework exercise as i use the book for self study, so any help will really be appreciated...
I think that energy and momentum conservation are needed. …
Hi george2! :smile:
Yes … and at the time of maximum extension, the relative velocity of the two masses will be zero, which gives you the extra equation you need. :wink:
Thanks for your reply!:smile:
I already used the fact that the relative velocity of the two masses will be zero at the time of maximum extension although i forgot to write that in my previous post.However i didn't get the right result.I will try it again later and if i don't find where my error is i will scan my attempt of solution...
I tried again but i didn't find the correct result...The fact that "the time of transit of the radiation is negligibly small compared to the period of oscillation" doesn't mean that the second mass has already absorbed the radiation by the time i apply energy conservation for the final moment?
Probably i write wrongly the conservation equations...could you write them?
I could :rolleyes: … but I'm not going to …
you write them! :wink:
I tried once more and finally i solved the problem.Anyway, thanks for the help:smile:
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
