Problem integrating gamma ray absorption model
The discussion revolves around integrating a gamma ray absorption model to understand the relationship between the thickness of shielding materials and the intensity of gamma radiation. The initial equation presented is ΔI = -μΔX, leading to the integrated form I = I0e^(-μx), where I0 represents the incident intensity. A participant seeks clarification on the origin of the term I0, realizing it corresponds to the initial intensity when slab thickness is zero, which serves as an integration constant. This insight highlights the importance of recognizing initial conditions in mathematical modeling. The conversation concludes with appreciation for the clarification provided.
d3ntr0n
In this lab various thicknesses of a few materials are placed between a source of gamma radiation and a couple different detectors. It is reasonable to assume that some small change in the thickness of the shielding would produce a proportional change in the intensity of the gamma rays measured on the other side. If we define I to be the incident intensity of the gamma rays upon the shielding slab of thickness ΔX, and the emerging intensity on the other side of the shielding to be I’ with proportionality constant µ, we can describe the hypothesis with the simple model:
I) = -μΔX
I
According to the lab manual the solution to the integration of this equation yields
I = I0e^(-μx) ; Where I0 is the incident intensity
[/B]
So for an infinitesimally small change delta, we would use the Latin 'd' giving
dI = -μdX
I
integrating both sides and exponentiating then yields
I = e^(-μX)
So where does the term I0 come from? Can someone show me where my error is?
When the slab thickness is zero there is an initial intensity. That corresponds to an integration constant.
Oh wow. Duh. Thank you gneill, I appreciate that.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
