Finding the Solution: Solving for [sin(alpha)]^2 in a Complex Equation
In summary, Alex is asking for help solving the equation [sin(alpha)]^2 = (A^2)/2 or 1, given the constants A and alpha. They have attempted to use the quadratic formula, but did not get the desired results. However, they have since solved the equation.
alexolcz
Hi I was wondering if anybody could help solve this equation. I have the answer but i can't seem to work out how my teacher arrived at this,
Many thanks
Alex
alpha
A = constant
Solve for [sin(alpha)]^2
A^2- [sin(alpha)]^2*(A^2+2)+2*[sin(alpha)]^4
The solution is given as
Welcome to PF!
Hi Alex! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
So you mean solve A2 - B(A2 + 2) + 2B2 = 0 for B?
Hi,
Thanks for your fast reply, sorry about the formatting I'm new to all this!
Yes that the question. I realize that it is basically a simple quadratic but when i try to solve it using to the quadratic formula I don't end up with the required results?
Thanks again
Alex
alexolcz said:
Hi,
Thanks again
Alex
Please post your work, so we can see where you are going wrong...
Hi,
I've just manage to solve it! Thanks for your offers of help, very kind.
Merry Christmas
Alex
1. What is the first step in solving an equation?
The first step in solving an equation is to identify the variable or unknown value in the equation. This will help you determine the operations needed to isolate the variable on one side of the equation.
2. How do you know if your solution is correct?
You can check your solution by plugging it back into the original equation and seeing if it satisfies the equation. If it does, then your solution is correct.
3. What is the difference between an expression and an equation?
An expression is a mathematical phrase that consists of numbers, variables, and operations. An equation, on the other hand, is a mathematical statement that shows the equality between two expressions. Equations have an equal sign, while expressions do not.
4. Can an equation have more than one solution?
Yes, an equation can have more than one solution. This means that there are multiple values for the variable that satisfy the equation and make it true.
5. What should you do if you encounter fractions or decimals in an equation?
If you encounter fractions or decimals in an equation, you should try to eliminate them by multiplying both sides of the equation by the common denominator. This will help you work with whole numbers, making the equation easier to solve.
