Solve Problem with Density: Find Object's Density
  • Thread starter Thread starter yoleven
    Density
To find the density of an object weighing 20 grams in air and 3.5 grams in a liquid with a density of 1.7 g/cm³, the correct approach involves calculating the volume displaced. The volume is determined by the difference in weight, leading to a calculation of approximately 9.7 cm³. The density is then calculated by dividing the object's weight in the liquid by the volume, resulting in a density of 0.36 g/cm³. However, it's important to clarify that mass, not weight, should be used in density calculations. The discussion emphasizes the distinction between mass and weight in solving density problems.
yoleven
if an object weighs 20 grams in air but 3.5 grams in a liquid of density 1.7g/c,^3
What is the density of the object?
density=m/v
v=20-3.5/1.7
=9.7
then, density would be;
d=3.5/9.7
=0.36
Is that correct?
yoleven said:
v=20-3.5/1.7
=9.7
This is good. (Units = cm^3, I presume.)
d=3.5/9.7
=0.36
Careful. What's the mass of the object?
thanks, as usual!
mass is a measure of matter not weight!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
