Problem with graph and logs
  • Thread starter lewisbedwell
  • Tags
    Graph
In summary, the relationship between voltage and time across an inductor is given by the formula v=Ae^(t/B), where A and B are constants and e is the exponential function. Using the experimental results of voltage and time, it was determined that the values of A and B are 2090.238 and -12, respectively. It is important to note that the slope and intercept of the graph should not be determined using adjacent points to avoid potential errors.
lewisbedwell
It is thought that the law relating the voltage (v) across an inductor and the time(t0) in milliseconds (ms) is given by the relationship v=Ae^(t/B). Where “A” and “b” are constants and “e” is the exponential function. The results of the experimentation are below:
V (Volts) 908.4 394.8 171.6 32.4 14.1 6.12
T (ms) 10 20 30 50 60 70
lnV=1/B.t+lnA
Show that the voltage and time is actually true, and then determine the values of the constants “A” and “B”.
To show that the voltage is true, we need to plot it as a straight line graph, before we do this we need to take the log of the volts as shown below in the new table.
Volts (log) 6.8117 5.9784 5.1452 3.4782 2.6462 1.8116
We can see that if we apply the log laws to the original formula, that the formula becomes:
lnV=1/B.t+lnA
y=mx+c
We can also see that this looks like the straight line formula. We can work from here to build up a graph so we can make sure that it is of a straight line
(Graph would be here)
We can now begin to analyse this graph and work out some of the unknowns. To begin with we can work out what the value would be if t=0 so the graph can be extended. We can work out how much the graph increases from the 20 seconds to the 10 seconds, therefore:
6.8117-5.9784=0.833
So what values do you get for A and B?
Btw, the numbers provided you do happen to give a very straight line, but in general that will not be the case. Have you been taught linear regression? If you are going to obtain the slope and intercept from just two points on the graph, as you have done, it would be better to choose two that are well apart. If you take adjacent ones then a small error in a y-value could lead to a large error in slope.
Likes 1 person
Hi thanks for the reply, I have just worked out the values of A and B, was really struggling with them for some reason. I have: A= 2090.238 and B = -12. Thanks for the pointer about not using adjacent points, I will have a rethink and use further away ones. It makes sense to! Thanks again. Really helped.
That's what I get too.
This means that if the graph was extended, the voltage at t=0 would be approximately 0.833. This can then be used to calculate the value of “A” by using the original formula and substituting in the values for “v” and “t”. This should give us the value of “A” as 2.299.
Next, we can use the graph to calculate the value of “B”. We can do this by finding the gradient of the line, which is equal to 1/B. To do this, we can take two points from the line, for example (20, 5.9784) and (70, 1.8116). The gradient can be calculated as:
(5.9784-1.8116)/(20-70)=-0.06832
Therefore, 1/B=-0.06832, and solving for B gives us a value of approximately -14.64.
Therefore, the final equation for the voltage and time relationship is v=2.299e^(t/-14.64). This shows that the original formula is true and the values for the constants “A” and “B” have been calculated using the graph and log laws. This can be used to accurately predict the voltage at any given time.
1. What is the relationship between graphs and logs?
Graphs and logs are closely related as logarithmic functions are often used to model and analyze data that can be represented in a graph. Logarithmic functions can also be graphed and visually compared to other functions on a coordinate plane.
2. How do I graph a logarithmic function?
To graph a logarithmic function, first determine the domain and range of the function. Then, plot a few points by choosing x-values and using the logarithmic function to find the corresponding y-values. Finally, connect the points with a smooth curve to create the graph.
3. What is the difference between a logarithmic scale and a linear scale?
A logarithmic scale is a scale in which the values increase by a constant ratio, such as powers of 10, rather than a constant amount. This allows for a wider range of values to be represented on the same graph. In contrast, a linear scale increases by a constant amount, making it more suitable for representing smaller ranges of values.
4. How can I solve problems involving logarithmic functions?
To solve problems involving logarithmic functions, you can use properties of logarithms such as the product rule, quotient rule, and power rule. You can also use the inverse relationship between logarithmic and exponential functions to solve for unknown variables.
5. Are there real-life applications of graphs and logs?
Yes, graphs and logs have many real-life applications such as in finance, physics, and biology. They can be used to model population growth, earthquake intensity, sound levels, and other phenomena that can be represented by exponential or logarithmic functions. They are also useful in data analysis and visual representation of data in various fields.
9K
