Problem with model answer to exam
  • Thread starter Thread starter madah12
    Exam Model
The discussion revolves around a disagreement with the model answer for a conceptual question on an exam regarding capacitors. The original poster argues that the answer should reflect that the capacitor is not connected to a battery, leading to changes in voltage and electric field. They assert that if the charge is constant and energy is doubled, the capacitance must be halved, which contradicts the notion of a battery connection. After consulting with an instructor, it is suggested that the energy increase implies a maintained voltage, which could justify the model answer. The conversation highlights the confusion surrounding the problem and the assumptions required for interpretation.
madah12
http://physics.ku.edu.kw/LectureNotes/TheoryCourses/PHYS102/ExamPapers/y1011-2-md2.pdf
so i just did this exam and they gave us model solutions and I don't agree with conceptual question number 1 the answer should be 2 because it isn't connected to battery therefore voltage should change
and so should electric field
E=(sigma)/k*e_0 , charge is constant k is equal to 2 so it should be halfed
i don't see why they conclude its connected to a battery? it says fully charged so who would connect a fully charged capacitor to a battery also it doesn't say it is connected
The energy stored in a capacitor is given by U_{Stored}=\frac{1}{2}\frac{Q^2}{C}\,.
If the charge on the capacitor is constant and some change is made to the capacitor which doubles the stored energy, that implies that the capacitance is halved. To do this by inserting a dielectric can only be done if a dielectric material of K replaces one of 2K . (That would double the electric field.) However, that goes against goes against the gist of the problem, which seems to imply (without stating so explicitly) that the capacitor initially has no dielectric.
This problem seems very confusing.
ok i talked to my instructor and he says we were supposed to infer that it was connected to battery because they said energy increases what do you think?
yeah i guess well I usually hate it if doctors go well this is so obvious if you can't do this then you don't understand anything.
