Solving Pulley Problem: Find T1, T2, W1, W2, Alpha
  • Thread starter Thread starter ana111790
    Pulleys
The discussion focuses on solving a physics problem involving a patient's leg supported by two weights connected through cables. The leg's weight is given as 300N, with specific distances and angles provided for calculations. The user has attempted to set up equations based on the sum of forces and moments for equilibrium but is unsure about the accuracy of their equations. They are advised to revise their force equations and include an equation for horizontal forces, while also considering Newton's third law for clarity. The key takeaway is the need for five equations to solve for the five unknowns in the problem.
ana111790
A patient's leg is held in position by 2 weights tht are connected through cables. The weight of the leg is W = 300N. L is the horizontal distance between the points where the cables connect with the leg (points A and B) and C is the center of gravity for the leg, located 2/3 L away from A. The angles from cable 2 is Beta=45 degrees.
Find T1, T2, W1, W2, and the angle Alpha for the leg to stay in equilibrium.
[PLAIN]http://img820.imageshack.us/img820/2055/drawing5.jpg
Sum of Fy=0
Sum of Fx=0
Sum of Moments = 0
So I separated the pulleys, so have for the weight and pulleys on left:
Sum of Fy= T1-W1=0
For the weight and pulleys on right:
Sum of Fy=T2-W2=0 (is this correct? What is the effect of the second pulley on the tension?)
Sum of Fy= T1sin(Alpha) - W +T2sin(45)
(Should these be T1sin and T2 sin or just T1 and T 2?)
Then I did sum of moments:
Sum of moments around point A = -W*2L/3 + T2sin(45)*L=0
Sum of moments around C = -T1sin(Alpha)*2L/3 + T2sin(45)*L/3
Sum of moments around B = W*L/3 + T1sin(Alpha)*L
So basically I'm stuck. Not sure if so far it's correct of how to proceed.
Can anyone help me out? Please.
You have 5 unknowns so you will need 5 equations. Your moments all look okay to me, but your forces need some revision. You need to revise your Fy equation, and create an equation for Fx. Remember to use Newton's 3rd law to work out any kinks.
