Problem with rope climbing mechanism
  • Thread starter Thread starter satman1
    Mechanism Rope
The discussion focuses on designing a rope climbing device that operates without electrical or chemical power. Key considerations include generating sufficient lifting force to overcome weight and friction, with suggestions for using mechanical power supplies like wound springs. The idea of allowing weight to fall and unravel from a pulley to facilitate upward movement is also proposed. There is uncertainty about the efficiency required for the mechanism to function effectively. Overall, the conversation emphasizes the need for innovative mechanical solutions to achieve the desired climbing capability.
satman1
Hi,
I need to figure out how to design a device that should climb on a rope without any
electrical or chemical plant (see the attached file for drawing).
I need a good idea how to generate sufficient lifting force in order to compensate weight
and friction?
You can use a mechanical power supply, right? Such as a winded/loaded spring?
I've been pondering this, and can't decide whether my scheme needs > 100% efficiency. :smile: I'm sure someone will soon set me right.
Allow that weight on the string to slowly fall and unravel from the pulley, and this turns the pulley so it advances up the rope. Is there a payload to lift, or just the light-weight pulley?
