How Can I Restore a Deleted Icon in Windows?
  • Thread starter Thread starter pmb_phy
    Windows
To restore a deleted icon for the search folder, users can check the Recycle Bin to see if the icon is still available for restoration. If the Recycle Bin has been emptied, the original folder can be found in the "My Documents" section under "Documents and Settings." The desktop icon is merely a shortcut, which can be recreated by right-clicking on the folder and dragging it to the desktop to create a new shortcut. An alternative solution is to create a new user account and transfer files, but care should be taken not to copy over problematic settings. For data safety, it's advisable to keep documents on a secondary hard drive and back up files on another PC or external drive to prevent data loss from hard drive failures.
pmb_phy
I accidentily deleted the icon which opens the search folder so I can view files. Can someone tell me how to find the program (i.e. location in system files) so I can restore it? Thanks.
Pete
Computer science news on Phys.org
The easy way... if you do not get a response from anyone who knows where the file is... create a new user account... move your files over to it... done.
Be careful about moving your entire "Desktop and Settings" folder over because you will end up copying over the problem. so... Internet settings, and your documents, favorites, etc can get copied over... just be carful about the desktop settings.
Did you empty your Recycle bin? If not, your icon's still there.
Start with DaveC426913's advice first. Right click on "Recycle Bin", select explore, click on the folder (shortcut) and select restore.
If you "emptied recycle bin", then the file you are looking for is the "My Documents" folder under "Documents and Settings". The icon on the desktop is just a short cut which can be restored.
One can 'right click' on a folder and drag it to the desktop, and select "create/make a 'shortcut'".
I actually prefer keeping all documents on a second HD, and using the primary HD for OS/Apps only. This way, if the primary HD crashes, I still have the second one with all the data/text files.
I also back up the data files on another PC or external HD. I have seen too many corrupted/crashed HD's.
I came across a video regarding the use of AI/ML to work through complex datasets to determine complicated protein structures. It is a promising and beneficial use of AI/ML. AlphaFold - The Most Useful Thing AI Has Ever Done https://www.ebi.ac.uk/training/online/courses/alphafold/an-introductory-guide-to-its-strengths-and-limitations/what-is-alphafold/ https://en.wikipedia.org/wiki/AlphaFold https://deepmind.google/about/ Edit/update: The AlphaFold article in Nature John Jumper...
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
