How Do You Find the Basis and Equation for Specific Subspaces in R^3?
  • Thread starter Jimmy84
  • Tags
    Subspaces
In summary, the first problem cannot be solved, the second problem asks to find a set B in R^3 such that each vector in S is a linear combination of vectors in B, and the third problem asks for how to write three equations as one vector equation.
Jimmy84
191
-Problem number 1
Given the set {u ,v} , where u=(1,2,1) and v=(0,-1,3) in R^3 find an equation for the space generated by this set.
-Problem number 2
The subspace S is defined as S= {(x,y,z) : x + 2y - z =0}
find a set B={u,v} in R^3 such that each vector in S is a linear combination of vectors in B.
I have no idea how to solve problem number 2.
I don't know how to find an equation for the space in problem one
I started the problem like this (a,b,c) =(1,2,1)x + (0,-1,3)y
and then I found x and y in terms of a and b. but I don't have an idea what is meant to find an equation for the space.
I would appreciate some help, thanks a lot.
  1. How about su+tv for real s and t?
  2. Find two vectors in the plane. To do this, try z=0, et cetera...
the answer for the first problem is 7x -3y -z = 0 but I don't know how to solve for that
what do you mean s and t?
  1. s and t would give the parametrized version of the plane. To get the implicit version they give, try the cross product, which gives the normal.
Jimmy84 said:
-Problem number 2
If you have three variables and only one equation, you can solve for one variable in terms of the others. For example, if you had x-2y-3z=0, you could solve for x and get x=2y+3z. Now let y=s and z=t, where s and t are your free parameters, so you have
\begin{align*}
x &= 2s + 3t \\
y &= s \\
z &= t
\end{align*} Can you see how to write those three equations as one vector equation?
1. What is a subspace?
A subspace is a subset of a vector space that satisfies the properties of a vector space. This means that it is closed under addition and scalar multiplication, and contains the zero vector.
2. How do you determine if a set is a subspace?
To determine if a set is a subspace, you must check if it satisfies the three properties of a vector space: closure under addition and scalar multiplication, and contains the zero vector. If all three properties are satisfied, then the set is a subspace.
3. Can a subspace be empty?
Yes, a subspace can be empty. This happens when the set does not contain the zero vector. However, it is important to note that the empty set itself is not a subspace.
4. What is the dimension of a subspace?
The dimension of a subspace is the number of linearly independent vectors in the subspace. This represents the minimum number of vectors needed to span the subspace.
5. How do you find a basis for a subspace?
To find a basis for a subspace, you can use the row reduction method to find the linearly independent vectors that span the subspace. These vectors will form the basis for the subspace.
