How Can We Calculate Artificial Gravity for Space Stations?
The discussion centers on calculating artificial gravity for a space station design in the ISSD competition. A participant is seeking assistance with an equation for artificial gravity, having struggled with their previous formula. They shared their earlier equation, which relates rotational speed to gravity produced and distance from the center of rotation. A response clarified that their equation is similar to the centripetal acceleration formula and provided a relationship between speed and rotational frequency. The participant expressed gratitude for the help and acknowledged the ongoing challenges in their project.
TSBasilisk
I'm a Junior, and I am participating in a competition. A team I am on annually joins in the ISSD competition, or International Space Settlement Design competition, which is sponsored by NASA engineers. Having participated since my Freshman year, I am currently working on the structural engineering of our proposed station.
However, I am stuck in a rut. My section deals with the production of gravity on the station. Last year, I managed to utilize an equation, which this year seems to work as effectively as a wet noodle for a weapon.
So, I was wondering if anyone can assist me in finding a viable equation for calculating artificial gravity production, or in translating my older equation, which I sadly forgot to fully detail.
Here is the closest translation of the equation from last year:
N= 1/2pi * square root of a/s
Where N=rotational speed(rotations per second/minute)
a=gravity produced(m/s/s)
s=distance from center of rotation(m)
The arrangement of the figures is what confuses me, along with units to utilize, although I'm fairly sure the posted units are correct. I can't find any source for this equation online. I remember that last year this equation gave me a lot of grief before I got it working. If there is a better equation, I'm more than willing to try it.
Your equation is equivalent to that for centripetal acceleration for a rotating system:
a = \frac{v^2}{r}
Where a is the acceleration, v is the speed, r is the distance from the center. You can relate speed (v) to rotational frequency (f) by: v=2π r f.
Hope this helps a bit.
Thank you. I'll have to slog my way through the rest of these problems, and hope I don't come out with ridiculously large numbers.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
