Programmable light switch hardware.
4 replies · 2K views
MonkOFox
Ok, I know this may sound silly, but I enjoy programming and want to take it to whatever level I'm able to.
Effectively I want to be able to (through programming) connect to a device that has some sort of electrical "switch" and by "switch" I mean, "A device that can control the flow of electricity in a given line of 110 electrical wire".
I don't know if you can buy these or not (the device that is). And if none are available I would like to know what components I would need to build something of this nature.
Next would be the task in which I implement some sort of serial interface on the device that can be sent bits for certain tasks (in this case on/off).
I know some of this may be over simplified, but any help to point me in the right direction would be awesome. I develop software for a living, so hardware isn't really my strongest area.
Thanks,
Justin
Have you looked at the http://en.wikipedia.org/wiki/X10_%28industry_standard%29" devices and software? smarthome.com sells a lot of this stuff.
From what it looks like, the X-10 devices have to be on their own little network and they are controlled from a central unit.
I could be wrong, but unless you can control the switch devices via a connection to a personal computer, then that is not exactly what I am looking for.
Thanks for the info though,
Justin
Yes, you can control them from your computer:
http://www.smarthome.com/2413UH/HouseLinc-2-INSTEON-Desktop-Software-with-USB-Interface-Dual-Band/p.aspx
About 10 years ago I wrote my own control software using Visual Basic. I could switch lights, appliances, and even set the temperature on my heat pump thermostat.
I'll have to look into those insteon products. I have an application that I'm working on that will execute certain hooks by vocal commands. I just need to make sure they have some sort of API I can use instead only their software.
I really appreciate the help man, now I have an idea of what I'm looking for : ).
Thanks again,
Justin
