Learn How to Program a 555 Timer for 4 Second Intervals | Tips and Tricks
To program a 555 timer for 4-second intervals, a monostable circuit is insufficient as it only produces a single pulse. Instead, an astable circuit should be used for generating multiple pulses, resembling a clock. Users are encouraged to explore resources like Crocodile Clips for demos on 555 timer programming. The community is supportive and offers assistance for any further questions about 555 timer configurations. Properly utilizing the astable mode will achieve the desired interval functionality.
Shahil
Hi!
I need to programme a 555 timer pulse with intervals of 4 secs. I've already tried connecting a monostable circuit I found on the net with values of a 36K resistor and 100uF capacitor but what's happening is it's going on for 4 seconds then off for the rest!
Here's the circuit that I tried working - anybody got anything better?? please :shy:
http://www.doctronics.co.uk/555.htm#monostable
You're looking for multiple pulses like a clock? If so, look further up the page at the astable circuit. A monostable is just that - mono for 1 pulse! :smile:
:blushing: :rolleyes:
Hmm...I always thought I was dumb...now u've just proved it! Thanks dude - will get back to you later and I'll tell you if it works!
Hey, If you go onto
"www.crocadile-clips.com" there's pretty good demo's on programming a 555 timer programme in monostable operation. But you have to download the free trial.
I'm pretty sure there is enough talent on this board to tell you everything you want to know about the 555. Just ask.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
