Projectile Jumper Problem: Finding Takeoff Speed
  • Thread starter Thread starter tuber313
    Projectile
The discussion centers on calculating the takeoff speed of a long jumper who lands 8.2 meters away after taking off at a 45-degree angle. Initial attempts to solve the problem reveal confusion over missing variables, particularly time and vertical height. Key insights include recognizing that the vertical displacement is zero upon landing and that the final vertical velocity is equal in magnitude but opposite in direction to the initial vertical velocity. The solution involves using the relationship between horizontal and vertical components of velocity, ultimately leading to a calculated takeoff speed of 9.0 m/s. The collaborative effort highlights the importance of understanding projectile motion dynamics in solving such problems.
tuber313
A long jumper leaves the ground at 45 degrees above the horizontal and lands 8.2 meters away. What is her "takeoff" speed v0?
x = x0 + v0t + 1/2at^2
v^2 = v0^2 + 2ad
v = v0 + at
I can't seem to figure this problem out. Here's the information I got from the problem so far:
x component:
x0 = 0
x = 8.2 m
a = 0
y component:
y0 = 0
a = -9.8 m/s^2There seems to be too many missing variables to solve the equation. I even tried breaking the projectile in half, which yielded me this:
x component:
x0 = 0
x = 4.1 m
a = 0
v = v0
y0 = 0
a = -9.8 m/s^2
v = 0
EDIT: I forgot to mention I also realize that v0x and v0y components are equal, since the angle is 45 degrees. I know this is important, but I can't connect it to anything.
I still can't seem to figure it out, since I need y, or how high the object goes at its highest point. I also can't figure out the time it takes... If I knew either of those, I could figure it out, but I can't seem to get anything from this.
Thanks for your help.
A few points you may find useful, for the full length problem
1) the jumper 'lands' - this means that at the end of the jump the y displacement is zero as she returns to the ground (y = 0)
2) the point above means that the final velocity in the y-direction must be equal in magnitude to the initial velocity but in the opposite direction (vy = -v0y)
3) you can solve for the time in the y-direction using v = v0 + at
I think you should be able to manage the rest. The trick is just to realize what's happened in the y-direction at the end of the jump.
i understand that y=0 and vy=-v0y...
what i don't understand is how you can use v = v0 + at to find the time, since you still don't know what v0 (or v) is.
I should just mention that time will be a function of the v0y. When you use this time in the equation for the x-direction velocity you'll end up with something like v0x * v0y = number. Then just use what you know about the angles to get the answer.
I solved it!
It wound up being 9.0 m/s, after I found the v0x=v0y=6.338769597
Thanks so much for your help!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
