Projectile, max height half the range, find angle
The problem involves determining the angle of projection for a projectile such that its maximum height is equal to half of its range. The context is within the study of projectile motion, focusing on the relationships between height, range, and the angle of projection.
  • Participants discuss setting the equations for vertical and horizontal motion equal to each other to find relationships between variables. There is an exploration of how to express time in terms of other variables and the implications of average speeds at maximum height.
Some participants have provided insights into the conceptual understanding of the problem, particularly regarding the relationship between vertical and horizontal speeds. Others have indicated they are slightly stuck at certain points, seeking further clarification on how to proceed with substitutions and calculations.
Participants note that the problem is constrained to finding the angle only, without needing to derive a complete solution or numerical answer. There is an emphasis on understanding the relationships rather than solving for specific values.
click0420
find the angle of the projection for which the maximum height is equal to half of the range
vertical: h =(vsinθ)t-0.5(g)(t^2)
horizontal: 2h =(vcosθ)t
i know you set both equations equal to each other
(vsinθ)t -(0.5)(g)(t^2) = ((t)vcosθ)/2
cancel t
(vsinθ)-(0.5)(g)(t) = (vcosθ)/2
(2vsinθ-vcosθ)/2 = (0.5)(g)(t)
at this point i am slightly stuck, i know i need to sub some equivalent form in for "t" though i am not sure how/what formulas to use.
cancel t
Go for concepts here.
At maximum height, the object is half way (horizontally) to its landing point - so at that point the height is 1/4 of the range.
The vertical part of the trip has been done while slowing down, so the average speed is 1/2 the initial speed.
It gets to a height 4 times its range so far, so the average vertical speed is 4x the horizontal speed.
Thus the initial vertical speed is 8x the horizontal speed.
Apply Pythagoras to that.
I was able to figure it out but thanks!
Re-reading to see that you were only after the angle, you merely wanted tan-1(8)
  • · Replies 21 ·
