Projectile Motion, Physics I with Calc. I
A ball is thrown from a roof at a height h, hitting the ground 1.60 seconds later, 24.0 m away at a 55-degree angle. The initial approach involved reversing the motion to calculate height, yielding a value of 21.73 m. The discussion highlights confusion regarding how to determine the initial velocity and its components, particularly after finding the height. Participants note that the equations for projectile motion need careful application, especially since the vertical velocity changes over time. Clarification is sought on the problem's wording and the equations involved in calculating the velocity at impact.
bohregard
A ball is thrown leftward from the left edge of the roof, at height h above the ground. The ball hits the ground 1.60 seconds later, at distance d = 24.0 m from the building and at angle theta = 55 degrees with the horizontal. (a) Find h. What is the (b) magnitude and (c) angle relative to the horizontal of the velocity at which the ball is thrown?
We know that the impact angle is theta = 55 degrees
x distance is 24.0 m
time for the ball to hit the ground is 1.60 seconds.
y-y0 = v0sin(theta)t - gt2/2
x-x0 = v0cos(theta)t
Vx = v0xt
Vy = v0yt
v0x = v0cos(theta)
v0y = v0sin(theta)
My first step was to solve for h. What I did was reverse the motion so instead of tossing the ball from the rough, we tossed it from the ground. I made the impact point the origin (0,0). Next I took my second equation and solved it for v0 which gave me x-x0 / cos(theta)t = v0. I plugged that into the first equation and then solved for y which gave me the value 21.73 m.
Now, here is where I get lost. I'm not sure exactly what to solve for. I thought maybe if I solved the equation backwards like I did for height I could find the impact velocity and make that my initial velocity. The problem is I don't know where to start. Any suggestions would be appreciated for sure!
Vx = v0xt
Vy = v0yt
v0x = v0cos(theta)
v0y = v0sin(theta)
What is the red equation for?
You sure part b is not missing a word?
Yup that's the question. The red equation is the y component of velocity.
Well for projectile motion that will not work as Vy changes through time.
Im thinkin the question intended to ask something about the velocity of the ball when it hits the ground and make some comparison with the initial conditions. But I cannot tell for sure.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
