The Time of Return for a Particle Undergoing Negative Acceleration
To determine when a particle undergoing negative acceleration returns to its initial position x_0, the relevant equations are v = v_0 - at and x = x_0 + v_0*t. The correct approach involves using the equation x = x_0 + v_0*t + 0.5*a*t^2 to account for the acceleration. Setting x equal to x_0 leads to a quadratic equation, yielding two solutions: t = 0 and another positive time value. This second solution represents the time at which the particle returns to its starting position.
estie
A particle leaves its initial position x_0 at time t=0 moving in the positive x direction with speed v_0 but undergoing acceleration of magnitude a in the negative x direction. Find expressions for (a) the time when it returns to the position x_0.
v=v_0-at
x=x_0+v_0*t
i know that v=v_0, but that gives me a time of 0, which doesn't make sense. I'm also not supposed to use x_0 in the solution. otherwise, i think the solution should be (v-v_0)/-a.
x=x_0+v_0*t
This formula is for uniform motion (zero acceleration).
You need to use x = Vo*t + .5*a*t^2.
When you set x = 0, you will have a quadratic equation with two solutions. One will be t=0 of course and the other greater than zero.
v=v_0-at
x=x_0+v_0*t
By the way estie, if you wish to use TeX-style notation on this forum you can wrap [ tex] [/tex] tags around your equations so it'll look more like this:
x=x_0+v_{0}t<br />
Welcome to PF!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
