Projectile Motion - Trajectory
To determine the minimum velocity and angle for a ball to clear a 100 m wall located 100 m away, one must apply the principles of projectile motion. The ball must be launched at an optimal angle, typically 45 degrees, to maximize horizontal distance while achieving the necessary vertical height. The vertical velocity needed to reach the wall's height can be calculated using the equation for vertical motion, factoring in gravity. The horizontal component of the velocity must also be sufficient to cover the 200 m distance to point B. A step-by-step calculation involving these components will yield the required launch velocity and angle.
melle_87@hotmai
There is a point A and point B, with 200 m distance between the two. In the center, there is a 100 m wall. What is the minimum velocity (and angle) a ball must be thrown to get over the wall?
Basically I'm clueless. I need step by step instructions.
THANKS!
What is the vertical velocity required to cross that wall?
