Projectile Motion word problem from Calc III course (finding height of a wall).
The problem involves projectile motion, specifically determining the horizontal distance to a wall that is 2 meters high when a ball is thrown at an angle of 60 degrees with an initial velocity of 20 m/s. The original poster seeks to find the distance to the wall, acknowledging that there are two possible solutions based on the projectile's trajectory.
  • Exploratory, Assumption checking
  • The original poster attempts to relate the range and height of the projectile but is unsure how to incorporate the height of the wall into their calculations. Some participants suggest focusing on the time it takes to reach the height of 2 meters to find the corresponding horizontal distance.
Participants are exploring different interpretations of the problem and discussing the necessary calculations. Some guidance has been offered regarding the need to calculate the time to reach a height of 2 meters, but there is no explicit consensus on the approach to take.
The original poster expresses a lack of recent experience with the concepts involved, indicating potential gaps in understanding the relationship between vertical and horizontal motion in projectile motion problems.
jtex316
The problem is from the MIT Open CourseWare Calculus eBook by Strang. Chapter 12.2, #3:
A ball is thrown at 60 degrees with initial velocity of 20m/sec to clear a wall 2m high. How far away is the wall?
Finding flight time T, range R, and max height Y(max) is the easy part. How do I find how far away the 2m-high wall is? I understand that this has two solutions (the wall is going to be really close to the launch point, or really close to the end point). How do I calculate the solutions? Please note that it's been a very long time since Physics I.
I've attempted to take the Range and subtract the height of the wall from it, but that doesn't work. I feel like instead of Y(max) I need Y(2m), but I don't know how to do that.
You don't need to work out the problem - a link to an example or a little push is all I'm looking for here.
Thanks!
The range is the distance the projectile moves horizontally, right? It doesn't really make sense to subtract a vertical distance from it. Remember that the motion in the horizontal and vertical directions are separate from each other.
I'm not clear on your notation here. Ymax usually denotes the maximum height the projectile reaches. Y2 m would tautologically be equal to 2 m.
Start by finding the time it takes for the ball to reach a height of 2 meters.
Hey there, thanks for your reply. Apparently it looks like I'm going to need to see the problem worked out. I have struggled with this, trying to use T, R, and Y(max) formulas and just don't see how to get to the answers as the author has.
The only way you can do this problem is to assume they mean that the ball just barely clears the wall. That is, as vela said, solve for the time it takes the ball to reach a height of 2m. Use that height to determine the horizontal distance the ball has gone.
If you have tried this yourself but don't get the answers the author has, show us what you have done, what answer you got, and what the author's answer is.
