Projectile Problem - Time of Peak
A fireworks rocket launched with an initial upward speed of 58 m/s will coast for approximately 5.9 seconds before reaching its peak. The equation t = v0z/g is applicable, where v0z equals 58 m/s, as the trajectory is vertical. While angles can affect the time to peak for angled launches, a straight-up launch is effectively at a 90-degree angle, confirming the use of the initial speed in calculations. The discussion clarifies that gravity is the only force acting on the rocket after launch, without any thrust. Thus, the time to peak is determined solely by the initial speed and gravitational acceleration.
courtney1121
If a fireworks rocket has an initial upward speed of 58 m/s when launched, for how long will it coast before reaching its peak?
So could I use the equation t=v0z/g?
When I use this I get the peak to be 5.9s. Is v0z = 58 m/s or would that be 0? Am I approaching this correctly?
Anyone have an idea?
well you need an angle because time would depend on the angle you use. For example if you launched the rocket at a 50 degree angle the time to reach its peak would be 58sin50 / 9.81 = 4.42 secs. But if you launched the rocket at a 70 degree angle it would be 58sin70 / 9.81 = 5.55 seconds. So you would have to specify the angle.
oh ok, so even if you shoot the firework straight up, it still needs an angle?
well straight up it would be 90 degrees. 58sin 90 / 9.81 = 5.912 seconds.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
