Proof involving vector spaces and linear transformations
killpoppop
1. Suppose V,W are vector spaces over a field F and that T: V ---> W is a linear transformation. Show that for any v belonging to V that T(-v) = -T(v)
2. -T(v) denotes the additive inverse of T(v)
3. I think I'm really overcomplicating it =/ But i have
0v = T( v - v ) = T(v) + T(-v)
Then add -T(v)
0v + -T(v) = T(v) + T(-v)
(T(v) + T(-v)) -T(v) = T(v) + T(-v)
then
T(-v) = T(v) + T(-v)
then i suppose it could go to
T(-v) = 0v
but that doesn't help I'm going round in circles. Basically i need a starting point.
Looks more like you need someone to tell you when to stop. :smile:
When you obtain 0=T(v)+T(-v), you're done. If T(-v) has that property, it is the additive inverse of T(v). You should however explain more clearly why T(v+(-v))=0.
Hm, are you allowed to use that 0x=0 for all x without proof? If not, it's easy to prove using the trick 0x=(0+0)x.
Cheers!
Right so when i get:
0v = T(v) + T(-v)
i just move the T(v) over because 0v=0?
giving
-T(v) = T(-v)
seems a bit too easy! I've already proved 0x=0 .
Can you explain more about
'You should however explain more clearly why T(v+(-v))=0.'
please =]
You shouldn't need to move anything over, you know that 0v = 0, therefore at the step where you have T(v) + T(-v) = 0 that means T(-v) is the additive inverse of T(v), remember what definition of additive inverse is!
I'm not sure if I can tell you anything new without giving you the complete solution. What you want to prove is that T(v)+T(-v)=0. And the proof of that goes like this:
T(v)+T(-v)=T(v+(-v))=...=0
Can you fill in the missing steps?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
