Proof of an inner product space
cabin5
Prove that the normed linear space l_{\infty}^{2} is not an inner product space.
parallelogram law;
\left\|x+y\right\|^2+\left\|x-y\right\|^2=2\left\|x\right\|^2+2\left\|y\right\|^2
Well, I tried to apply parallelogram law to the l_{\infty}^{2} space where
x=(\alpha^1,\alpha^2) and y=(\beta^1,\beta^2)\in l_{\infty}^{2} .
\left\|x\right\|=max\left\{\left|\alpha^1\right|,\left|\alpha^2\right|\right\} and <br /> <br /> \left\|y\right\|=max\left\{\left|\beta^1\right|,\left|\beta^2\right|\right\}
If one puts these norms into the parallelogram law equation, one gets a fuzzy expression on both sides of the equation, therefore it is important to put out expressions inside the max{} function which I could not achieve to do.
Is there another method to solve this problem or am I misapplying the law to l_{\infty}^{2} space?
You only need a counterexample to show it's not an inner product space. Start putting some actual numbers in for the alphas and betas.
Is it a mathematically correct method?
What would not be 'mathematical' or 'correct' about it? If I claim all primes are odd, and somebody points out 2 is even, that's enough to prove me wrong. Just do it.
Yes, as Dick said, proving that a general statement is NOT true by counterexample is a perfectly correct method.
thanks for the post!
well,
I tried the parallelogram law for x=(0,3) and y=(2,5) and it perfectly worked on both sides of the equation.
Should I choose the complex field for that space?
What's wrong with that?
You must have put some effort into find a case where it works. Almost all other cases don't work. Like x=(1,0) and y=(0,1). It has to work for all cases or your norm doesn't come from an inner product.
Finally, It worked :)
I thought any ordered pair would work as a counterexample.
Thanks a lot!
No, and ordered pair won't work because R2 DOES make a inner product space. This question was about l_\infty^2. Your counterexample must be from that space. What are the vectors in that space?
I took it to be R^2 with the max norm. You think it's bounded functions on R^2, right? It's still pretty easy to find a counterexample with bounded functions.
I have no clue whether one must use a bounded function or not in order to prove that.
The question is, what is the definition of the space l^2_infinity? Can you tell us what it is?
Sorry for so late reply:
The definition of l_{\infty}^{n} :
On the linear space V_{n}(F) with the infinity norm defined by
\left\|x\right\|_p=\left[\sum^{\infty}_{i=1}\left|\alpha^{i}\right|^p\right]^{1/p}
where x=(\alpha^i).
The corresponding linear space to this norm is denoted by l_{\infty}^{n}.
No, I was assuming infinite sequences {an} such that {a2n} was summable.
so l_{\infty}^{2} defines that norm which is basically the square of root total sum of square of each element of 2 vectors defined over R^2 field.
Eventually , I think that you're example is correct, but besides I have no idea about whether functions defined in l_{\infty}^{2} is bounded or not (since I didn't take any real analysis course during undergrad.)
I don't think that's what the problem is supposed to be about.
I think what you just described is l^2_2. The 'infinity' usually designates a max norm (supremum) rather than a power root norm.
oh, ****!
you're right , It was supposed to be max norm! I miswrote the definition.
