Defining Groups: Proving Abelian Property
  • Thread starter Thread starter wubie
    Groups Proof
The discussion revolves around proving the abelian property of a group G, specifically addressing two parts of a mathematical question. Part (i) asks to prove that (xy)² = x²y² if and only if xy = yx, with hints provided on using group definitions. In part (ii), it is established that if g² = u (the identity element) for all g in G, then G is abelian, leading to the conclusion that xy = yx. Participants clarify how to apply the given information and definitions to arrive at the necessary proofs, enhancing their understanding of group properties. The thread concludes with a positive acknowledgment of the assistance received in grasping these concepts.
wubie
[SOLVED] Proof Using Def. of Groups
Hello,
This is my question:
Let G be a group.
i) Let x and y be elements of G. Prove that (xy)2 = x2y2 iff xy = yx. (Hint: Use the definition g2 = gg).
ii) Using part (i) prove that if g2 = u (the unit element) for all g which is an element of G, then G is abelian.
Now I BELIEVE that I have properly proved the part (i) of the question. But I am not sure how to proceed with part (ii). In fact, the second part question makes me wonder if I did part (i) correctly.
I know that the definition of abelian is:
For every x and y which are elements of G, a group G with the property x o y = y o x is called abelian ( or commutative). To rephrase, I would think this is the same as F(y,x) = F(x,y).
Now I am not sure what the definition would be in context of the question. Is the question saying,
Proposition: If g2 = u then xy = yx?
Is that the proposition that I am supposed to prove? And if that is the case, I am still not sure how to use the nfo g2 = u. How does it apply to the relation in part (i)?
In the case of part (i) would this be it?
x o y = x2y2. Then
x o u = x = u o x --> x2 * u = x = u * x2? (In which case 1 would be the identity element. Correct?).
Any help/clarification is appreciated. Thankyou.
Yes.
Consider the product fg, where f and g are both in G. Since the group is closed, fg is also in g. We then must have, according to the info they gave (gg=u):
(fg)(fg)=u
Right multiply by gf:
(fg)(fg)(gf)=u(gf)
Can you take it from there?
x o y = x2y2.
That should be (x o y)o(x o y)=(x o x)o(y o y).
Right. Then if f and g are elements of G then by definition of a group, f o g is an element of G.
Where u is an element of G by definition of a group and also by the aforementioned property. Correct?
(fg)(fg)=u
(fg)(fg)(gf)=u(gf)
Yes. I can see it now. Perhaps you did too much in this step.
OH! That helps! It's like a composition function right? For instance,
q = F(y,x) = x * y and
G(q)= G (F(y,x)) = q * q = F(y,x) * F(y,x) = (x*y)*(x*y).
This would be the same for the right side of the equation yes?
I will be back later and post the proof.
Thankyou Tom.
Yes; the group must have an identity element.
For instance,
Right.
In the language of your function F(x,y), you have:
F(x,y) o F(x,y)=F(x,x) o F(y,y)
Right.Right. My mistake. Thanks a lot Tom. Your help has been great increasing my understanding of the subject.
Cheers.
