Prooving 2 Vector Eqn Lines Are Perpendicular
To determine if two vector equations of lines are perpendicular, one can use the scalar product rule, where the dot product of their direction vectors should equal zero. The direction vectors for the given lines L1 and L2 are derived from their equations, and the gradients affect the angle between them. By maintaining the gradients while shifting the lines, the angle remains unchanged, confirming that the gradients are the key factor. For a new question about finding a perpendicular line, the gradient can be adjusted based on the desired direction, and both potential gradients can be valid as long as they maintain perpendicularity. Understanding these concepts simplifies the process of proving perpendicularity in vector equations.
ku1005
Hey, just hoping sum1 new a better way to do the follwing Q other then the way I'm doing it!
it gives 2 vector eqn's of lines L1 and L2 as follows:
L1 = r = (2i+4j)+k(-1i+3j)
L2= r = (-3i+1j)+m(6i+2j)
(ie k= lambda and m=mew- also they are inform matrice form but i didnlt now how to type i into that format so sorry for that)
i was converting them to cartesian eqn y=mx+c, then the gradients must multiply =-1...howveer i suspect u can use the scalar product rule (ie a.b = 0 for perpendicular lines) but i can seem to work the equations to give me = 0...any assistance or hints would be greatly appreciated!
thanks
i cant* cant* lol eem to work it to giv me = 0
Go through the scalar product rule again, maybe you accidentaly mixed up some vector components or so (not that I'm underestimating you, don't get me wrong :wink: ).
With the lines, think about what part of the equations affect the angle between them. Then find the scalar product of that certain part of the equations.
i still keep getting a wole lot of mews and lambdas which don't cancel to give 0? what do you mean by the part that effects the angle between them...given the intially position vector and then adding the variable vector...shoulnt the angle be the same regardless of value of mew and lambda as this just should extend the line...? sorry i don't get wat you mean
ok. If you have two lines, such as shown below:
http://img85.imageshack.us/img85/5746/g1au4.jpg
The two lines make an angle with each other. The equations of each line are shown in the top right hand corner.
If you keep the gradient of each line the same, but move it up/down and left/right, like so:
http://img143.imageshack.us/img143/6462/g2te0.jpg
Notice how the angle between the lines is exacly the same. You could then say that the only thing that affects the angles between two lines is the gradient of each.
In those vector equations, think about what part is the gradient. And then see if you can work from there.
dam ur good at explainin! lol
:biggrin:
So you understand the question now? :smile:
dam...how com is so easy when u put it like that!
simply usin a.b= 0 for perpendicular lines and given gradient will be determining factor for angle
-6(lambda)(mew)+6(lambda)(mew)=0
thanks heaps...really helped
Glad it makes sense now :smile: Glad to be of assistance :smile:
whilst ur still there with the following...almost the same Q...fincd the vector equation of the line perpendicular to:
vecotr eqn r = (2i-j)+(lambda)(3i+2j) and passing through point a,position vector (4i+3j).
My Q is, i get the gradient down to either (2i-3j) or (-2i+3j), with the answer being the latter, how do you make th decision that the latter is the corret combination...?
Shouldnt matter i would think.
Look at it like this.
http://img148.imageshack.us/img148/9992/yeane4.jpg
See the red point at <4,3>? Try going left 2 units, and up 3, and draw a line between the two points <-2,3>. Now try going right 2 units, and down 3, <2,-3>, and again draw a line. The lines will align with each other, giving the same result :)
thanks again...thats what i thought (ie that they wil both be perpendicular...ie they seem to be the same line) just checkin since answer only gave one...but thanks again!:)
