Can Object A Be Neutral Based on Charge Interactions?
The discussion centers on whether object A can be neutral based on its interactions with objects B and C. A and B attract each other, while B and C repel, leading to questions about A's charge. It is clarified that a neutral particle does not experience attraction or repulsion from charged particles, but can still be attracted through polarization. The participants agree that A could indeed be neutral, despite the limited information available. The conversation suggests that the problem would be clearer if framed around three point-like charged objects.
kickthatbike
Three objects (A, B, and C) are brought close to each other one at a time. A and B attract, but B and C repel. Simple true/false question involving "is this one positive/negative/etc." What I'm unsure about is whether or not A could possibly be neutral, or more specifically, is there any way to tell with certainty based on the limited information whether or not it IS neutral?
There are no neutral charges, only positive and negative charges. A neutral particle is neither attracted to nor repulsed by a charged particle.
Fair enough. Thank you!
A charged object can attract neutral ones by polarizing them. A rubbed plastic rod (or a simple comb) will attract small and light paper pieces. See: http://www.physicsclassroom.com/class/estatics/u8l1c.cfm (experiment with a rubbed balloon and bits of paper). So you are right, A can be neutral, too.
The problem should have been asked about three point-like charged objects.
ehild
