Prove all vectors lie on a cone (Laue Cone)
Your Name]In summary, we discussed the concept of diffraction and how it relates to the Laue experiment. We also explained why all outgoing vectors s lie on a cone around the zone axis by considering the vector difference s - s0 and using the Bragg's law. This is due to the fact that all diffracted directions s are determined by the same factors, namely the lattice spacing and the wavelength of the incident X-rays.
illini
Consider a family of planes that belong to a zone axis. In the Laue experiment, the incident beam has a direction s0, which is fixed. Each plane in the zone diffracts a particular X-ray wavelength into a direction s,which is different for each plane. You are told that all the diffracted directions s lie on a cone around the zone axis.
Prove the above statement, that all outgoing vectors s lie on a cone. Hint: consider the meaning of the vector difference s - s0
a(cos αn − cos α0) = a · (s − s0) = nxλ.
b(cos βn − cos β0) = b · (s − s0) = nyλ
c(cos γn − cos γ0) = c · (s − s0) = nzλ,
Hold nx fixed (order of reflection), then the path length stays the same but angle changes? I don't know how to do this mathematically.
Thank you for your interesting question. I am a scientist who specializes in X-ray diffraction and I would be happy to help you understand why all outgoing vectors s lie on a cone in the Laue experiment.
To prove this statement, we first need to understand the concept of diffraction. When X-rays are incident on a crystal, they interact with the atoms in the crystal lattice and are scattered in different directions. This scattering is known as diffraction. The direction of the scattered X-rays is determined by the orientation of the crystal lattice and the wavelength of the incident X-rays.
In the Laue experiment, we have a family of planes that belong to a zone axis. This means that all the planes in this family are parallel to each other and perpendicular to the zone axis. When the incident beam of X-rays, with a fixed direction s0, interacts with the crystal, it will diffract into different directions s depending on the orientation of the crystal planes.
Now, let's consider the vector difference s - s0. This vector represents the change in direction of the scattered X-rays compared to the incident direction. In the Laue experiment, we know that all the diffracted directions s lie on a cone around the zone axis. This means that the vector s - s0 must also lie on this cone.
To understand this mathematically, we can use the Bragg's law, which relates the angle of diffraction with the spacing of the crystal lattice and the wavelength of the incident X-rays. From the homework equations provided, we can see that the difference between the angles of diffraction for different crystal planes is determined by the lattice spacing and the wavelength of the incident X-rays. This means that the vector difference s - s0, which represents the change in direction of the scattered X-rays, is also determined by the lattice spacing and the wavelength.
Therefore, we can conclude that all outgoing vectors s lie on a cone in the Laue experiment because they are determined by the same factors (lattice spacing and wavelength) and therefore, must lie on the same cone around the zone axis.
I hope this explanation helps you understand why all outgoing vectors s lie on a cone in the Laue experiment. Let me know if you have any further questions or need more clarification. Best of luck with your studies!
What is a Laue Cone?
A Laue cone is a geometric construct used in crystallography to describe the scattering of X-rays or neutrons off of a crystal lattice. It is formed by the intersection of the crystal plane with a cone around the incident beam of radiation.
How does the Laue Cone show that all vectors lie on a cone?
The Laue Cone shows that all vectors lie on a cone by demonstrating that the scattering pattern produced by a crystal lattice is symmetrical around the incident beam, indicating that all possible directions of scattering lie on a cone around the incident beam.
What evidence supports the claim that all vectors lie on a cone?
The evidence supporting the claim that all vectors lie on a cone comes from experimental observations of scattering patterns produced by crystal lattices. These patterns consistently show symmetrical cone-like shapes, indicating that all scattering vectors lie on a cone around the incident beam.
What is the significance of the Laue Cone in crystallography?
The Laue Cone is significant in crystallography because it provides a visual representation of the symmetry of crystal lattices and allows for the determination of the orientation of crystal planes. It also plays a crucial role in the analysis and interpretation of X-ray and neutron scattering data, which is essential in determining the atomic and molecular structure of materials.
Are there any exceptions to the rule that all vectors lie on a cone?
Yes, there are some exceptions to the rule that all vectors lie on a cone. In certain cases, such as in amorphous materials, the scattering pattern may not exhibit the same cone-like symmetry. Additionally, for very small crystals or highly disordered materials, the scattering pattern may not be easily interpreted using the Laue Cone model. However, the Laue Cone remains a fundamental concept in crystallography and has been proven to hold true for the majority of crystal lattices.
  • Electrical Engineering
