Prove the convergence of a limit
  • Thread starter Thread starter Felafel
    Convergence Limit
Felafel
it should be all right this time, but could you please check my solution?
prove the convergence and find the limit of the following sequence:
##a_1>0##
##a_{n+1}= 6 \frac{1+a_n}{7+a_n}##
with ## n \in \mathbb{N}^*##
the sequence is increasing, and its two possible limits are the solution of the associated equation: 2; -3.
However, I have to exclude -3, because being ##a_1>0## and the sequence increasing, it can't converge to a negative number.
Saying it converges is equal to saying that:
for every ##\epsilon<0## there exists a n* s.t. for every n≥n* we have:
##|a_n-L|<\epsilon##
being L=2 in this case and ##a_{n+1}>a_n>a_{n*}## we have
##\frac{6+6a_n}{7+a_n}-2|<\epsilon##
and
## |\frac{6- 14 -2a_n+6a_n}{7+a_n}|<\epsilon##
which holds for every
## a_n> \frac{-7\epsilon-8}{4-\epsilon}##
##a_1>0##
##\displaystyle a_{n+1}= 6 \frac{1+a_n}{7+a_n}\ \ ## with ## n \in \mathbb{N}^*##
for every ##\epsilon>0## there exists a n* s.t. for every n≥n* we have:
##\displaystyle \frac{6+6a_n}{7+a_n}-2|<\epsilon##
##\displaystyle \quad\quad \quad\quad \left|\frac{6+6a_n}{7+a_n}-2\right|<\epsilon##
and
##\displaystyle \left|\frac{6- 14 -2a_n+6a_n}{7+a_n}\right|<\epsilon##
You have a few typos in your post. I cleaned some up and enlarged some fractions.
##\displaystyle \frac{-7\epsilon-8}{4-\epsilon}\ \ ## is negative for ε < 4 .
If a1 > 2 , then the sequence is decreasing.
great, thanks!
would it be better then, if i wrote:
which holds for
##\displaystyle \frac{-7\epsilon-8}{4-\epsilon}>0##
with
##\epsilon>4##
Felafel said:
great, thanks!
which holds for
with
##\epsilon>4##
No. Not at all.
You need to show that \displaystyle \ \left|\frac{6+6a_n}{7+a_n}-2\right|&lt;\epsilon\ \ for all ε > 0. The crucial situation is when ε is very small.
should i put it like that:
##|\frac{7\epsilon+8}{4-\epsilon}| > a_n## which for ##\epsilon## going to 0, goes to 2? --> ##a_n<2##
What you need to show is that for all n > n*, \displaystyle |a_n-2|&lt;\varepsilon\ .
If you can find a way to define an in terms of n and a1, then the ε-n* proof described above is appropriate.
I have worn out WolramAlpha, messing around with this problem.
I haven't worked with recursively defined sequences lately... but here's an idea.
If the sequence an is monotonically increasing, which it is if 0 < a1 < 2, and if the sequence has an upper bound of 2, then all you need to show is that for ε > 0, there is a n>0 for which ak > 2-ε .
Now that I consider that, that's not easy to do either.
##a_1>0##
Acutally if a_1 &gt; 2 then the sequence is monotonic decreasing. What is true is that if a_n &gt; 0 then a_{n+1} &gt; 0, so if a_1 &gt; 0 then certainly the sequence cannot converge to -3.
With sequences defined by recurrence relations, it's best to note that if |a_n - L| is monotonic decreasing, then it is bounded below (by 0, as absolute values always are) and so |a_n - L| must converge to a limit. Hence a_n converges, and given how L was determined a_n must converge to L.
The condition for |a_n - 2| to be monotonic decreasing is that |a_{n+1} - 2| &lt; |a_n - 2| for all n. Now
<br /> \left|a_{n+1} - 2\right|<br /> = \left|6\frac{a_n+1}{a_n+7} - 2\right|<br /> = \left|\frac{4a_n - 8}{a_n + 7}\right| = \frac{4}{|a_n + 7|}|a_n - 2|<br />
which means that |a_{n+1} - 2| &lt; |a_n - 2| if |a_n + 7| &gt; 4. This holds, in particular, if a_n &gt; 0. Since a_1 &gt; 0 and if a_n &gt; 0 then a_{n+1} &gt; 0, |a_{n+1} - 2| &lt; |a_n - 2| for all n. Hence a_n tends to a limit, which in the circumstances must be 2.
