Proving a function is not bijective
  • Thread starter mahler1
    Function
mahler1
Homework Statement .
Let ##f:\mathbb R \to \mathbb R## be the function defined as ##f(t)=t+2t^2sin(\frac{1}{t})## if ##t≠0## and ##f(0)=0##. Prove that ##f## is not bijective in any neighbourhood of ##0##. The attempt at a solution.
I've tried to prove that is not injective. The only idea I had in mind (later I realized it was completely wrong) was to suppose there is a neighbourhood of ##0## where the function is bijective. Then, there is ##\epsilon>0## such that ##B(0,\epsilon) \subset U##. I considered ##t_1=(2k\pi)^{-1}## and ##t_2=(-2k\pi)^{-1}## with ##k \in \mathbb N## such that ##k>(2\pi\epsilon)^{-1}## (I can find such ##k## by the archimidean property of the natural numbers), then ##t_1## and ##t_2## are in ##U##.I did all that without considering that ##f=t+2t^2sin(\frac{1}{t})##, I thought of the function ##f=2t^2sin(\frac{1}{t})##, the term ##t## ruins me everything because it takes into account the sign. Can anyone suggest me a different approach?
Your function is differentiable. If a function is bijective and continuous on an interval, then clearly it has be monotone increasing or decreasing. Can you think of a way to use the derivative to show that isn't true? You can use parts of your previous argument here.
