Proving Maximal Ideal I in Noncommutative Ring R with Unity
  • Thread starter Thread starter Fizz_Geek
5 replies · 3K views
Fizz_Geek
Question:
Find a noncommutative ring R with unity, with maximal ideal I such that R/I is not a field.
Attempt at a solution:
Let R = the set of all 2x2 matrices with integer entries.
Let I = the set of all 2x2 matrices with even integer entries.
I'm having trouble proving that I is maximal. The only way I know to do that is to assume I is not maximal, therefore it is contained within a maximal ideal J, then show that J = R. But I'm stuck. I haven't been able to prove that J = R.
Any help is appreciated!
Well, I don't know whether it is maximal either, but let's find out together. Denote [tex]M=M_2(2\mathbb{Z})[/tex]. Assume that there exists an ideal [tex]M\subset I\subseteq M_2(\mathbb{Z})[/tex]. Our goal is to show that [tex]I=M_2(\mathbb{Z})[/tex].
So, take an element [tex]A\in I\setminus M[/tex]. Then we can assume without loss of generalization that
[tex]A=\left(\begin{array}{cc} 2a+1 & b\\ c & d\end{array}\right)[/tex]
So, we assume that the first element is odd. We know nothing about b, c and d, they may be odd or even.
Now, the elementary matrix [tex]E_{i,j}[/tex] is such that there is a 1 on place (i,j) and a 0 on all other places. For example,
[tex]E_{2,1}=\left(\begin{array}{cc} 0 & 0\\ 1 & 0 \end{array}\right)[/tex].
Now the goal is to multiply A by suitable elementary matrices to simplify the form of A. For example, we might reduce A in the form
[tex]A=\left(\begin{array}{cc} 2a+1 & 0\\ 0 & 0\end{array}\right)[/tex]
and since we obtained this form by multiplying by elementary matrices, this means that this must be an element of I. So, try to reuce the form of A into a suitable form. Once you've done this, we'll try to see what our next step is...
So I did what you asked, and I multipled on the right and left by E1,1. This gives the desired matrix. And I know this matrix is an element of I because I is an ideal and absorbs products.
The train of thought I was following started out the same, but I was trying to modify the given matrix so that I could prove that the identity matrix was contained in I. That's where I got stuck.
Can I ask where you're going with this?
We're also trying to show that the identity matrix is in I. The method with elementary matrices is a standard method of proving such a thing...
Now, try to prove that
[tex]\left(\begin{array}{cc}1 & 0\\ 0 & 0\end{array}\right)[/tex]
is in I. Then try to multiply this matrix by a certain matrix to conclude that also
[tex]\left(\begin{array}{cc}0 & 0\\ 0 & 1\end{array}\right)[/tex]
is in I. Adding these matrices together will get you the identity matrix!
Oh, I got it!
You wouldn't happen to know any good resources with examples on this elementary matrix method, would you?
I really appreciate your help, thank you very much!
There is really nothing more that we can say about elementary matrices. It's just a trick that you know now. I think you know as much about elementary matrices as me right now...
But maybe you could read en.wikipedia.org/wiki/Elementary_matrix but it doesn't contain much more than you already know.
