Proving the square root of a positive operator is unique
Adgorn
The problem relates to a proof of a previous statement, so I shall present it first:
"Suppose P is a self-adjoint operator on an inner product space V and ##\langle P(u),u \rangle## ≥ 0 for every u ∈ V, prove P=T2 for some self-adjoint operator T.
Because P is self-adjoint, there exists an orthonormal basis{ ##u_1,...,u_n##} of V consisting of eigenvectors of P; say, ##P(u_i)=\lambda_iu_i##. Since P is self-adjoint, the ##\lambda_i## are real, also, since ##0≤ \langle P(u_i),u_i \rangle = \lambda_i\langle u_i,u_i \rangle## and ##\langle u_i,u_i \rangle ≥ 0##, ##\lambda_i## ≥ 0 for all ##\lambda_i##."
The rest of the proof defines ##T(u_i)=\sqrt{\lambda_i}u_i## for i=1,...,n and shows how ##T^2=P##
Now for the question itself: Consider the operator T defined by ##T(u_i)=\sqrt{\lambda_i}u_i##, ##i=1,...,n## in the above proof. Show that T is positive and that it is the only positive operator for which ##T^2=P##.
2. Homework Equations
N/A
I have already proven that ##T## is positive with relative ease, my problem is proving its uniqueness. I have tried to define a second positive operator ##T'## such that ##T'^2=P## and show that ##T'=T##. I've tried showing they agree on a basis, using their properties as self-adjoint operators by messing around with inner products and so on but with no success.
Help would be appreciated.
N/A
Why do you need uniqueness? The question (if accurately reproduced) does not claim that the ##T## you get is unique. (In fact, it cannot be unique, since both ##T## and ##-T## satisfy the theorem!)
The original proof does not say claim T is unique but a remark below it says "The above operator T is the unique positive operator such that ##P=T^2##, it is called the positive square root of P". In any case even if the theorem does not claim it, the question asks me to prove it.
Also while ##-T## might satisfy the theorem it does not contradict the question since the questions asks to prove T is the only positive operator for which ##T^2=p##, since ##-T## is clearly not positive it is not relevant to the question.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
