Pull a rectangular loop through a magnetic field
The discussion revolves around solving a physics problem related to a rectangular loop moving through a magnetic field. The key equations involved are E = vB and F = qVB. The poster is confused about the correctness of multiple-choice answers regarding the behavior of the loop in the magnetic field, specifically questioning the validity of options 1, 2, and 3. Clarification is provided that option 1 is correct, option 3 is incorrect, and option 2 requires consideration of the current's direction using the right-hand rule. Understanding the right-hand rule is essential for determining the magnetic field direction for each segment of the loop.
xzibition8612
Please see attachment.
E=vB
F=qVB
My question is the last part "which of the following are true". I've tried these choices and all were wrong:
(1, 2, 3)
(1, 2)
(2)
(1, 3)
I really am confused. I swear 1 is right. Right? 2 seems to be right, and 3 should be wrong. But right now I'm confused and don't know what is what. Any help is much appreciated.
Yes, 1 is indeed right, and 3 should be wrong. For 2, think about which direction the current is flowing in. Use the right-hand rule to find out the direction of the magnetic for all segments of the loop.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
