Pulley system, find the acceleration and tension
40 replies · 7K views
Davidllerenav
Given the picture:
  • Make the free body diagrams of each body and the pulley. Remember that there are two different strings therefore there are two different tensions.
  • Assuming that the mobile of mass M starts from rest and has a displacement D at a time t, and the bodywith mass m falls a height h at the same time, calculate the accelerations of the mobile a_1 and the body a_2 (Note: Use only cinematics).
  • Assuming that the accelerations of the bodies are known, calculate the tensions in the strings, and the coefficient of friction between the mobile and the table. Despise the pulley mass and friction between pulleys and rope.
Kinematics equations.
Ok, So for the first one, I made the diagrams of each body like this. Is it correct?
For the second one, it says that the mobile of mass M starts from rest, so ##v_0M=0##, and ##v_M=at##. The displacement would be ##D=\frac{at^2}{2}+D_0##, so the acceleration would be ##a_1= \frac{V_M}{t} = \frac{2D}{t^2} + D_0##.
Now, for the body with mass m I set the inicial speed as ##0##, so ##v_0m=0##, thus ##V_m=-gt##. The Fall would be ##F=h-\frac{gt^2}{2}. Thus ##g= -\frac{v_m}{t} = h-\frac{2F}{t^2}. Am I correct?
For the third one, I don't know what to do. Pleas help me.
It's a bit hard to read the details on your diagrams, but the tensions don’t look right.
If a string passes over a pulley, and the pulley is considered massless and frictionless, what can you say about the tensions in the two segments of string?
That they are the same.
But that does not seem to be what either of your pulley diagrams show. As I wrote, they are hard to read though.
Yes, sorry I think I labelled them wrong. But I think that on Pulley 1, both tensions are the same, right? On pulley 2 the tensions on the left are the same and the one on the right is the same as the tension on pulley 1. The tension that mass M feels is the same as the left ones on pulley 2 and the tension that mass 2 feels is the same as pulley 1, right?
Yes, that all sounds fine.
Your equation for D is ok, but you can set D0=0. We are only concerned with the displacement.
Davidllerenav said:
The Fall would be ##F=h-\frac{gt^2}{2}##. Thus ##g= -\frac{v_m}{t} = h-\frac{2F}{t^2}##. Am I correct?
what forces act on m?
Tension and gravity.
Note that the FBD of pulley 1 is not correct. If those were the only forces acting on it it would accelerate down and to the left. However, this is irrelevant to the problem itself as what you need is the relation between the tensions in the string going left and that going down. This is a very common mistake that you should aim to avoid. Even though it does not matter in this problem, there are problems where it will matter.
There should be a force pointing up and a force pointgin right, is it correct? But what are those forces?
Look at the figure. What other forces on the pulley are available that you did not draw in your diagram? (It does not need to be two separate forces, it is sufficient to have one force pointing up and right.)
So will the acceleration be g?
Note that fir this part of the question you are told to take its a celeration as just a2.
The only one I can think of is the one provided by that support.
Oh, so I just need to change the g to a ##a_2##?
That's what the support is for, to supply whatever force is needed to keep it in place.
So it wold provide a force that isn't pointing up or right, but I need to find it's components, right?
You know that it has to balance the two tension forces, so which direction must it point?
It must point up and right.
haruspex said:
At what angle?
##45## degrees,right?
Right, it is a side-track to your problem and you do not need to care about it here though. However, as I said, there are problems where the support is attached to some mass that is movable and then it will matter so it is good to get this right from the beginning. I suggest you move on with the rest of this problem now and don't spend too much time on the support forces, but being aware of it is good practice and sometimes necessary.
Ok, thanks. I will have a test about this tomorrow on my lab class, so maybe the teacher wants to see the support forces. But one question, would't that change the sum of forces?
It is the only thing that makes it possible for your pulley's centre of mass to not accelerate, so yes. Without the support forces, the forces on the pulley cannot be equal to zero unless the tension is zero. The equality of the tensile forces is due to torque balance (assuming that the pulley is mass- and frictionless), because the support force is acting through the pulley centre of mass, but without the support force the pulley centre of mass would accelerate (which goes against the entire idea that it is fixed in place).
If I was your teacher and asked you to draw the forces on the pulley I would deduct points for not drawing the support force.
haruspex said:
Yes.
Ok, thanks. Sorry to ask here, but I posted I question before this one about circular motion, can you help me with it?
Ok. But one question. The third part says that there is acceleration, so what happens to those forces?
There is no (linear) acceleration of the pulley. It is locked into place by the support.
Oh, sorry I confused it witht he mass. So the pully is at rest always. The other one is too right?
No, the other pulley will have to move. If it did not move the hanging mass would not be able to move. However, it is supposedly massless in this problem. Note that there is no separate support keeping it in place.
So it would move to the right, pulling the mobile and letting the hanging mass to fall?
